06-04-2021, 04:58 PM | #1 |
1938 Woody Transmission Cover
I'm looking for a sheet metal transmission cover. Are they all the same?
Bradley Floor Pans makes one for "1937 & 1938 cars" I'm wondering if that includes S/Wagons. |
06-05-2021, 08:20 AM | #2 |
Re: 1938 Woody Transmission Cover
Station wagon pan is the same. Be VERY aware that actually obtaining a pan from Bradley has a success rate near zero.
06-05-2021, 08:46 AM | #3 |
Run a want ad on this site for the transmission pan. I'll bet you will get a good used one. Unless Brandley has it "currently" in stock you'll probably never see it in your lifetime.
06-05-2021, 08:48 AM | #4 |
Good advice indeed.
06-05-2021, 10:55 PM | #5 |
MEMBER EMERITUS
37 and 38 are pretty much the same.
39's are wider across the top and have a semi-circular cutout on the upper LH side. |
06-05-2021, 11:38 PM | #6 |
However, the "Tin Doctor" has been in touch with a cover. |
