Old 05-25-2021, 12:45 PM   #1
Hoppers29
Default Jack under seat
Do you keep a jack under your seat? An original or something newer? I'm starting to take longer and longer drives in my 29' RPU and want to be able to change out a wheel if need be. Thanks!
Hoppers29 is offline   Reply With Quote
Old 05-25-2021, 12:56 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Jack under seat
I keep original screw jack/ handle under the seat, the crank/lug wrench on the floor because I give hand cranking shows often, also under the seat are parts I never need because I have them
Old 05-25-2021, 01:01 PM   #3
antiquepa
antiquepa's Avatar
Yes, I do. Just to be on the safe side, don't wait till you need it. Before that time comes you should check to see if the jack will reach the axel before you need it. Found out the hard way, you may need to carry a piece of a 4x4 to sit the jack on, this will give you the height if the jack doesn't
go high enough.
antiquepa is offline   Reply With Quote
Old 05-25-2021, 01:08 PM   #4
Model A Ron
Model A Ron's Avatar
Do the supplier make a reproduction tool kit with a jack? I do not have a jack in the car at this time and I am starting to put on some serious miles.
Model A Ron is offline   Reply With Quote
Old 05-25-2021, 02:59 PM   #5
700rpm
700rpm's Avatar
I keep a jack and piece of 2x6 about 10" long to establish a firm base in case I need it on soft or uneven ground.
Ray Horton, Portland, OR
Old 05-25-2021, 03:12 PM   #6
1931 flamingo
1931 flamingo's Avatar
AAA card in the wallet..................and a cell phone.
Paul in CT
Old 05-25-2021, 03:27 PM   #7
jayvee34
jayvee34's Avatar
i carry the original screw jack, a hydraulic jack, crank handle lug wrench, 4 way lug wrench, 2x6x12 board, not under the seat but out back in the trunk .
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-25-2021, 03:29 PM   #8
Ed in Maine
I use a bottle jack only because it is compact and can be expanded to do the job. 700rpm makes a very good point. My pressure treated 2x6 is about 8 in. long! I also carry a folding lug wrench because the crank does not work well on a really tight lug nuts. The lug wrench is a cross shaped affair but two arms fold up on itself for easy carrying. I did modify the bottle jack because the top of the jack was poorly made, too small. I welded a small channel piece on to the top so that it would engage the front axle and support the rear axle. Another topic would be "what spare parts do you carry at all times." Happy Motoring, Ed
Old 05-25-2021, 05:18 PM   #9
WHN
Paul in CT
I like your style.
Enjoy.
Old 05-25-2021, 07:49 PM   #10
Tacoma Bob
Tacoma Bob's Avatar
I have a trunk with 4 army surplus ammo cans filled with different things. In one of the ammo cans I carry a bottle jack which I needed on a rear tire blow out.
Tacoma Bob is offline   Reply With Quote
Old 05-25-2021, 10:03 PM   #11
mgambuzza
mgambuzza's Avatar
I had to read this twice as I first thought you said you carry a bottle of Jack - maybe to have while waiting for the tow.
mgambuzza is offline   Reply With Quote
Old 05-26-2021, 03:35 PM   #12
Tacoma Bob
Tacoma Bob's Avatar
Originally Posted by mgambuzza View Post
i had to read this twice as i first thought you said you carry a bottle of jack - maybe to have while waiting for the tow.
lmao!!!!!
Old 05-26-2021, 10:15 PM   #13
700rpm
700rpm's Avatar
Put the jack in a box. You’ll be surprised when you need it.
Old 05-27-2021, 07:23 AM   #14
DkFordor
Originally Posted by 700rpm View Post
put the jack in a box. You’ll be surprised when you need it.
lol
DkFordor is offline   Reply With Quote
Old 05-27-2021, 09:34 AM   #15
WTSHNN
WTSHNN's Avatar
Another vote for a bottle jack. Cut out a piece of old carpet or rug to fit the pan and it'll help cut down on rattles.
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 05-27-2021, 11:58 AM   #16
KGBnut
KGBnut's Avatar
My jack isn't original, but it is period correct. And, yes, it fits very nicely under the seat in my coupe.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 05-27-2021, 10:19 PM   #17
eagle
eagle's Avatar
An original or near original jack in good shape is easy to find at a swap meet, I see them often for $10 or less. They work well and are small enough for easy storage.
