Old 05-09-2021, 12:18 PM   #21
nb141fd
Default Re: Torque tube shortening recommendations
AnthonyG, it's going to be a standard hot rod; 30 coupe on a 32 chassis with 8BA, 39 box, TT, 40 rear end, big and littles and fender less.
nb141fd is offline   Reply With Quote
Old 05-09-2021, 03:48 PM   #22
Karl Wolf
Karl Wolf's Avatar
Mitchell Overdrive was kind enough to cut splines on a solid shaft for me,
might have been around 15 years ago. The turn around time is dependent
on their timing. They do a bunch all at once. Then not.
Karl
Karl Wolf is offline   Reply With Quote
Old 05-10-2021, 01:51 AM   #23
Fortunateson
I have an early and late '32 rear ends. Can the bells interchange? Anything else?
Fortunateson is offline   Reply With Quote
Old 05-10-2021, 06:00 AM   #24
glennpm
glennpm's Avatar
Originally Posted by nb141fd View Post
Thanks for the tips guys. I think that the TT will have to be shortened so much that most leave the bearing out of the tube. Also, thanks for the indexing tips.
The bearing is toward the front and will and should remain.
The attached are reference dimensions and notes from my 40 rearend in my 32.
Glenn
File Type: pdf Installing a Columbia in a '32_Redacted.pdf (1.10 MB, 41 views)
Old 05-10-2021, 10:52 AM   #25
nb141fd
Hey Glenn, thanks for the dimensions and advice on keeping the bearing, will do.
Tony
Old 05-11-2021, 06:55 PM   #26
Talkwrench
Talkwrench's Avatar
Hanford Auto Supply
· 200 E 6th St, Hanford, CA 93230 Talk to Timmy
This maybe a bit far for you? Im sure he has a machine that welds...
