Old 05-11-2021, 05:30 AM   #3
jwmckenzie
Default Re: Model B Distributor in a Model A
The Model B is timed at 19degrees BTDC.
If you have a Model A timing gear cover, the crankshaft has to be backed up 19degrees, after the pin drops in the camshaft gear.
If you have a Model B timing gear cover, rare. The pin will drop in at 19degrees BTDC.
jwmckenzie is offline   Reply With Quote
