Old 04-30-2021, 01:59 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 36 frame from a 60 motor
Like Bill says above, remove the wimpy V8-60 mounts that merely rivet to the "REGULAR" chassis front crossmembers. Once you remove the "60" brackets, you'll see the big holes for the 'big' engine mounts. DD
After removal, the biscuits and donut mounts for the 'big' engine just fall into place. Hope this helps! DD
Click Links Below __
T5 W/TORQUE TUBE
