Originally Posted by Veeder
I have the original 3 speed on the column transmission that about fivery years ago shortly after I rebuilt the thing the cone gear and slide gear was damaged. I purchased (at the time) a transmission to fill the gap but since day one I noticed (I think) an ever so slight difference in gear ratios.
So I'm attempting to truly identify this cone gear as there are about 15 different ones that will fit.
I have the following tooth count 29,24,18, & 14 with the shaft approx. 1 1/8 inches.
I believe the correct number s 022A-7113A.
I'm hoping to be sure I'm correct as I need to buy one and also a slide gear with 29 teeth.
Any help is appreciated!
Bob
If all of the teeth are helical cut you have the correct part number for the cluster gear (cone gear as you say).
good luck
