Old 04-14-2021, 12:12 AM   #1
coxswain98
Default Electric fan over a belted fan
Any opinions about running an electric fan and omitting the belted fan? Horsepower savings? Electric fans are crap?
coxswain98 is offline   Reply With Quote
Old 04-14-2021, 03:52 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Electric fan over a belted fan
OK, I'll bite! As "someone" once famously said: "Electric fans are crap!"
Resorting to using an ELECTRIC fan because you can't figure-out how to employ a mechanical (Belt-driven) fan, is just as bad as taking your little sister to the prom......'cuz you couldn't get a real date!
So, I really speak from experience...(the FAN part, NOT the sister part). Click this link (BELOW) for a thread I posted some time back on the 'Barn describing how fellow 'Barner "Heard" and myself designed and built a mechanical fan to fit his 1936 Ford coupe with an 8BA engine, which leaves precious LITTLE room for a mechanical fan because of the radiator leaning-back on '35 & '36 Fords. DD
https://www.fordbarn.com/forum/showthread.php?t=278828
Click Links Below __
T5 W/TORQUE TUBE
Old 04-14-2021, 04:01 AM   #3
Yoyodyne
Yoyodyne's Avatar
How noisy is that compared to a stock 36 fan? I'd like to reduce the highway speed fan noise.
Yoyodyne is offline   Reply With Quote
Old 04-14-2021, 04:07 AM   #4
jrvariel48
jrvariel48's Avatar
I'm using an electric fan because I don't really have a choice. I'm running a supercharger so there's no real way to get a fan set-up in there. My 2 cents
jrvariel48 is offline   Reply With Quote
Old 04-14-2021, 06:39 AM   #5
Ol' Ron
Ol' Ron's Avatar
I have an electric fan in the roadster.
Old 04-14-2021, 07:02 AM   #6
mfirth
Had an electric 6 volt on my 52 Vic when i got it. Scrapped it, put new Standt 180 stats in it & ran stock fan. Runs 180 most of the time, 190 0n hot days in Ohio.
mfirth is offline   Reply With Quote
Old 04-14-2021, 07:05 AM   #7
Mart
Mart's Avatar
I like electric fans as long as they are:
1, not overly "on show".
2, not too noisy.
I have 4 early fords and they all have electric fans. My observations are:
1, you hardly ever need to use them (in the Uk climate)
2, you don't even need one when the carb is moving along.
3, it saves the mech fan noise when moving along at higher speeds.
4, it saves engine power.
So with apologies to my learned fellow board contributors, I prefer them.
Mart.
Old 04-14-2021, 07:26 AM   #8
hotrodcbx
There was an interesting test on horsepower draw using various fan types on you tube (believe it was motor wars). Dyno tests showed the "flex" type fan, as used by Coopman showed the worst fan for horsepower loss. The least loss was from the viscous type fan which is basically a temperature driven clutch type fan. Back in the day I ran a flex fan on my SS/H Cobra Jet after removing the clutch fan. My best time was 11.56 at 112 mph. Wish I still had that car, I sold it in 1975 when you couldn't give those cars away for $1000.00. Probably could have shaved 1/10 second if I left the stock one on.
hotrodcbx is offline   Reply With Quote
Old 04-14-2021, 07:28 AM   #9
Gene1949
Gene1949's Avatar
2, not too noisy.
Mart.
5, maximum cooling (airflow) stoplight to stoplight
6, very difficult to find a modern car (since mid '90s) without one. Hmm, I wonder what "they" know??
Gene1949 is offline   Reply With Quote
Old 04-14-2021, 07:53 AM   #10
Jack E/NJ
Jack E/NJ's Avatar
hotrodcbx>>>Dyno tests showed the "flex" type fan, as used by Coopman showed the worst fan for horsepower loss.>>>
Wasn't it Ralph Nader who also once famously claimed these fans were unsafe at any speed? Or was that some other part? Jack E/NJ
Old 04-14-2021, 11:16 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
That's interesting! "PeterC" has that big ol' S.Co.T. / Italmeccanica Supercharger mounted in his gorgeous '35 3-window, and has managed to squeeze-in this big ol' six bladed "Commercial" fan. DD
T5 W/TORQUE TUBE
Old 04-14-2021, 11:47 AM   #12
solidaxle
solidaxle's Avatar
Electric fans will do the job if you don't have a way to install a mechanical one. All depends if you want a nostalgia look or not. I was able to squeeze a mechanical fan in on my 32 with an blown 8ba.
Lets see pictures of what you have.
solidaxle is offline   Reply With Quote
Old 04-14-2021, 11:58 AM   #13
Tim Ayers
Bobby Green of Old Crow Speed Shop took 1/2 of the metal blade guard from an old fashion house fan to make a "cover" for an electric fan. That simple addition made it look old timey. I thought it was a neat solution in helping to hide the modern looks.
Tim Ayers is online now   Reply With Quote
Old 04-14-2021, 12:09 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Now that is a somewhat interesting approach. MY problem with the electrics is that they stick-out like a sore thumb, and drastically take-away from any nostalgic look of a traditional hot rod. They just look like a "crutch', or an afterthought.....to me. Now, the SOUND produced by electrics.....that's a whole 'nuther issue! DD
T5 W/TORQUE TUBE
Old 04-14-2021, 12:20 PM   #15
AnthonyG
AnthonyG's Avatar
I use both, electric on a thermo switch set & 200. Only comes on at stop lites & stop & go traffic. I went with a push type Spal behind the grill in front of radiator, you can’t even see it. I have manual shutoff so it doesn’t run with ignition off. I like it😁!
Nomad
AnthonyG is offline   Reply With Quote
Old 04-14-2021, 01:34 PM   #16
Ggmac
Electric and mechanical. Good thing about electric , blades hardly ever come off , at least thats what I hear . I guess anything is possible but if a electric fan blade comes off , I doubt itll leave a dent in your hood .
Old 04-14-2021, 01:35 PM   #17
Ol' Ron
Ol' Ron's Avatar
serpentine belt drive for ad and PS
Old 04-14-2021, 03:58 PM   #18
jrvariel48
jrvariel48's Avatar
My belt tensioner for the blower sits right where the fan would go. No can do!
Old 04-15-2021, 08:28 AM   #19
Kube
Super Moderator
Kube's Avatar
I find it funny that folks still, to this day, pick on Nader. Corviar's were built with a KNOWN safety issue that killed many folks. Why? Because the fix back then was about $6 per car.
Ralph had the testicular fortitude to bring that information to the public.
Old 04-15-2021, 09:37 AM   #20
4t8v8
Yeah. Ralph is my hero. Wish we had more like him. No. Wait. We do! I drove a Corvair and a Pinto for years and somehow managed to survive.
4t8v8 is offline   Reply With Quote
