Old 04-07-2021, 08:46 AM   #2
flatjack9
flatjack9's Avatar
Default Re: 1940 Ford V8 ID
39 and 40 were basically the same engine except for the ports for the temp senders. 40 used an electric sender so the ports were drilled straight through while the 39 had a ledge in the hole. Many things were changed on these engines over the years. The side shift was introduced for 1940.
