#21 |
Rob, I too use the Penrite 85-140 gear oil.
They are a well respected Aussie company that have for years produce oil specifically for veteran, vintage and classic vehicles. I spoke to their tech guy about this and they claim it is safe for our Ford V8 boxes. I pulled my 38 gearbox apart after 2000 miles, looking for a noise which I have never tracked down. The oil was clean and the bronze bits were unmarked after 2 years using the gear oil. Good enough for me. Dave |
#22 |
After Jseery’s post that reminds me of the time I drained everything on my Ford Aerostar.
I put gear oil in the five speed transmission. The next day I had a hell of a time shifting it. I looked up the specs and it said to use ATF! I changed it to ATF and it was just fine for the rest of the years I had it. Aerostar five speeds had T5 trannies in them. I always liked the gear ratio spacing in that vehicle. |
#23 | |
"Came too close to dying to stop living now!" |
#24 |
I am in the process of purchasing a 1933 pickup. I have an instruction book for 4 cylinder cars and trucks. It says to use SAE250 in the summer for transmission and rear axel. All I can find advertised is synthetic. Any thoughts on this? I would rather ask a stupid question than do something stupid
#25 |
The call outs for lube was evolving during this time period. If you look at the Ford specs in the late 30 and into the 40s they are recommending want is now GL4. You could also use GL1.
#26 |
#27 | |
In that same thread, it was stated that the active sulphates in other GL-5's only corrode/discolor brass when oil temps are in the 250°+ range, not something I'd expect in an old Ford.
'52 F-1, EAB flathead |
#28 | |
#29 |
Anybody using #30 motor oil in their standard transmissions? Thats what I have in the four speed T17 in my IH Loadstar. The manual calls for straight mineral oil #50 so this is a little lighter than they recommend. Seems to work great.
https://www.youtube.com/user/roosty6/videos |
#30 |
Not at all; Lucas is GL 4/5 and very reasonable
No job’s done ‘til it’s all done |
#31 |
Here is the comparison between the different viscosity ratings. But keep in mind that the additives are very different between them.
#32 |
So according to the chart my #30 motor oil is close in viscosity to an #85 gear oil.
#33 |
Yep, but again different additives.
