My horn sort of works but sounded like it was running on a dying battery. I took it apart today because I replacing the radiator and here's what I found inside. Can someone tell me what happened and what a fix might be? My car was converted to 12V so this may be a resistor that someone added but I don't have experience with the horn so any tips are appreciated!
Should be able to adjust the sound of the horn with one of the screws on the backside of the horn. Im not to sure about the picture. Looks like a resistor that has gotten pretty hot. Not sure if thats what should be in there or not.
Good things take time |
A voltage dropping resistor is the only way to keep a 6-volt design from sounding like a banshee for a high current draw component like a series wound horn motor. Perhaps the resistor has a bit too much resistance. Resistors make heat so that heat has to be disipated rapidly to keep the resistance within parameters. I would try a resistor that is made to drop voltage for such devices.
This link illustrates a dropping resistor mounted to a heat sink. other sources sell this type as well. https://www.modelaparts.com/a13803 |
#4 | |
![]() Quote:
I once found a brush spring had been overcompressed and the brush was barely making contact, that gave it a very weak ahooga, more like a oaah. Tightening the adjuster screw just bound it up. Took it apart, stretched the spring back (as I waited for replacement) and it worked just fine.
Looking at that resistor, I think it would either work or it wouldn't. But that does look hot. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
The dropping resister in your horn has burned out. Most on the market cannot handle the power requirement. They work fine as long as you don't blow the horn.
The best solution is to replace the two field windings for 12-volts. It is not a difficult job, just tedious. Attached article describes how to do it. Tom Endy |
If you have a 12 volt car follow Tom's advice above. His statement on horn resistors is also correct. My car is 12volts for the A/C! I rewound the field coils and the horn works great.
Thanks Tom! That burned resistor in the document looks just like my burned resistor lol!
