Old 03-26-2021, 02:00 PM   #1
3twinridges
3twinridges's Avatar
Default Holley 94 throttle shaft
I have a new Holley 94 throttle shaft. Fits really nicely in the throttle bore with zero play. The lever needs to be peened onto the shaft end. How would be the best way to do this without damaging or bending the brass shaft?
JB
File Type: jpg 7F04FA8F-4A3C-4178-AE3D-35C5DD88FA34.jpg (28.5 KB, 40 views)
3twinridges is offline   Reply With Quote
Old 03-26-2021, 04:27 PM   #2
GaryU.
GaryU.'s Avatar
Default Re: Holley 94 throttle shaft
I would think a vise with soft jaws(rubber around the new shaft) and as close to the lever as possible would work. Then a drift to peen the brass lever end down. Help me guys, where's CharlieNY to chime in. Be patient more experienced help is on the way.
GaryU. is offline   Reply With Quote
Old 03-26-2021, 04:33 PM   #3
3twinridges
Thanks Gary, originals seem to have a deeper hole drilled in the end for a better mushroom. I was thinking the same on the vise with an air hammer. Figured somebody on here has done this with good results.
JB
Old 03-26-2021, 04:45 PM   #4
flatjack9
flatjack9's Avatar
How about tapping the shaft so you could use a machine screw to hold it in place?
Old 03-26-2021, 05:36 PM   #5
Charlie ny
Jack's got it.....I use a 6 - 32 BUTTON head allen screw. If you go this way it is best to
grab the shaft in a lathe to drill the hole before tapping. The manufacturer fixtured
everything and smacked the end of the shaft HARD. This operation rolled the brass over
but most importantly caused the brass to bulge out against the 'hole' in the arm.
I just reread your post....if you have an air hammer and soft jaws in a good vise that might work too.
Charlie ny
[email protected]
716 440 8952
Old 03-26-2021, 05:47 PM   #6
3twinridges
Thank you Charlie. I annealed the end of the shaft and have a few air hammer bits that I think will work. The vise part is what concerns me, I do not want to oblong it with too much tension. I will play with it a little tonight and report back.
JB
Old 03-26-2021, 06:56 PM   #7
Rustyspokes
Rustyspokes's Avatar
I would think , Clean both sides of the Plate on a small wire wheel and the Brass shaft and Sweat Solder the shaft in place, both sides, it can always be reheated and moved if desired at any time , nothing will get damaged MHOpinion .. R
Rustyspokes is offline   Reply With Quote
Old 03-26-2021, 06:57 PM   #8
3twinridges
Rusty what type of solder/flux would you use there?
JB
Old 03-26-2021, 07:14 PM   #9
Rustyspokes
I would use the Paste solder Flux and a good grade of solder 50/50 or Better
Old 03-26-2021, 08:32 PM   #10
Ziggster
Whatever you do, do not hammer on the end of the shaft without it being completely supported inside another tube with very little clearance. I started tapping on the end of one of mine while I held in in a vice, and it promptly collapsed like a pretzel.
Ziggster is offline   Reply With Quote
Old 03-26-2021, 10:00 PM   #11
tubman
tubman's Avatar
I second this. The "slots" in the shaft for the butterflies make it very weak.
Old 03-27-2021, 08:16 AM   #12
3twinridges
I plated out the accelerator lever this morning. I chucked the shaft up in a vise with two oak pieces and slowly peened out the shaft with a trim hammer. I worked back and forth on peening it and expanding it with drift hits to the drilled hole. It turned out ok and tight. Doesn’t look factory but close.
My black oxide kit should be here Monday and I can dip the base and complete the carb assembly. Thanks for the help guys, much appreciated!
JB
File Type: jpg 2C0B8B69-E1C5-469D-9F8E-DF22D72D3FE4.jpg (42.6 KB, 59 views)
File Type: jpg F9BF1413-1951-47C1-A426-EC00DAAD3DF3.jpg (64.8 KB, 54 views)
File Type: jpg B1F1109C-28CF-446C-ADFA-B231E7981EDC.jpg (66.6 KB, 56 views)
Old 03-27-2021, 06:26 PM   #13
Ggmac
JB
Did you anneal brass by getting hot and dropping in cold water . Doing it like steel will do nothing .
Never mind , i see its already done
Old 03-27-2021, 06:58 PM   #14
3twinridges
Yes that is how I did it and it was still hard as rock LOL! I didn’t get it as hot as I normally would, I was afraid of annealing too far down the shaft and causing early shaft wear.
JB
Old 03-27-2021, 07:11 PM   #15
Pete
I hold the shaft in a lathe collet and peen with a flat face punch and hammer.
