hello
I have a 1923 t i have had a true fire system for over 30 years but i think it is going bad i am going to switch back to the coils and timer and roller assy my questions is witch way dose the roller go on the shaft which part of update I found that the wire harness from coil box to timer was bad replaced and now back to driving again thanks for all the suggestions it helped very much Kevin Last edited by kwisor; 03-28-2021 at 12:19 PM. Reason: Update |
The slot in the roller is oriented to the front of the car. The pin is then placed into the slot and hole in the cam shaft. Then place the small cap over the cam shaft so it covers the head of the pin. Then place the nut on the end of the cam shaft to hold everything in place.
Murphy proof.
Unless you have one of the camshafts with the hole all the way thru!
I know the voices aren't real but damn they have some good ideas! ![]() |
Never seen it. I cannot picture Ford drilling the hole all the way through. Think about the mess he would have had with production.
https://www.google.com/search?client...e+drilled+thru
The earlier cams had the hole drilled all the way through.
I bet that was fun.
Not bad if you remember which way the brush/roller mounted at TDC.
You wouldn’t need to know TDC otherwise.
You are going to need find TDC to time it properly anyway.
i have the roller on and coils it runs better but on a slight incline it has no puwer and when shifting into high it stumbles and take a little time to get up to speed. i do not have a compression gauge. next i will look at the intake gaskie it has been a long time since they have been change. at least i can drive now before i could not get around the block
thanks for all the replays i will keep you posted it will be next saturday before i can look at it again kevin |
#13 |
Stumbling could be: driver, too lean fuel mixture or wrong spark setting. Or, all three.
#14 |
hello redmodel t
i have the copper gasket buti will replace it has been on there a long time. when i turn it off it will back fire thank you kevin |
#15 |
Do know how to do a vacuum leak test? Check for vacuum leaks first, don't just replace something to replace it unless it needs replacing.
#16 |
hello
no i do not know how to do a leak test thank you kevin |
#17 |
Start the motor, play the tip of an unlit propane torch around where the intake attaches to the block. If there are any changes in RPM or motor sound you may have vacuum leak. You could also try WD-40 or oil.
#18 |
thanks i will give it a try
kevin |
