Old 03-21-2021, 05:08 PM   #1
throwback
Default Need a new or rebuilt 1951 ford 6 cylinder water pump
Can anyone tell me where I can get a new or rebuilt 6 cylinder Water pump for a 1951 Ford Custom 6 cylinder engine?
Thank You!
throwback is offline   Reply With Quote
Old 03-21-2021, 05:36 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: Need a new or rebuilt 1951 ford 6 cylinder water pump
Is it the 226 I6?
Old 03-21-2021, 05:39 PM   #3
throwback
It is a straight 6 cylinder. I assume it is a 226.
Old 03-21-2021, 05:42 PM   #4
cmbrucew
cmbrucew's Avatar
Rare to find one. I bought a small rebuilt waterpump with the same size shaft (diaXlength) and put the new shaft,bearings and seal into my housing. Don't break your
pulley or impeller. Small press is handy.
Skip may rebuild your Pump for you.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-21-2021, 06:18 PM   #5
KiWinUS
KiWinUS's Avatar
The auction site and very expensive.
Old 03-21-2021, 06:25 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Check Advance Auto Parts
Old 03-21-2021, 07:48 PM   #7
throwback
Thank You!!
Old 03-21-2021, 09:43 PM   #8
FortyNiner
FortyNiner's Avatar
The 226 water pumps are not reproduced and need to be rebuilt using your core. They are tricky to rebuild for the casual mechanic without a proper press. Best bet is to go to a known rebuilder. A number of members on FTE have used Cowboy John in Florida with good results. I've got a backup unit ready to head his way.
You'll want to be very careful with the thermostat housing as they are prone to cracking and are also not reproduced.
https://cowboyjohnsautoparts.com/
Old 03-21-2021, 10:03 PM   #9
GB SISSON
GB SISSON's Avatar
I had a guy in Oregon rebuild a studebaker flathead six pump about two years ago. Of course I didn't save the receipt or info. He only rebuilds waterpumps. There was something in his business name about a 'Dutchman'
Old 03-29-2021, 09:57 PM   #10
throwback
I sent it to Skip Haney in Florida for rebuild.
Thanks!
Old 03-30-2021, 07:58 AM   #11
cubflyer
I have a complete engine run a bowl sitting in the stand if you’re interested also J and I in Marshfield rebuilds Pumps
cubflyer is offline   Reply With Quote
Old 03-30-2021, 08:06 AM   #12
cubflyer
Complete engine 250 J&i 18004682439 4174682439 good people do starters and alternators and generators
Old 04-07-2021, 02:31 PM   #13
amodel25
amodel25's Avatar
Kanter Auto Parts lists them.
amodel25 is offline   Reply With Quote
