Has anyone installed a 6 volt 3 terminal solenoid on a Model A Starter Motor to eliminate the manual foot starter? Is there a diagram as to how this is done with wiring etc.
Thanks to all who respond to my question. |
Here's one for Model T, probably works the same.
Thanks very much, that diagram does help.
Don't you need to lock the starter switch in the closed position or something also?
I had the solenoid / key setup on a sedan when I purchased it. I had to reach through the steering wheel with my left hand to turn the key while I pulled the choke with my right. I quickly took it off and went back to original. It was much easier.
Bill Cilker, Jr Unrestored 190A Victoria 45B, & 160B Victoria Association President |
#6 | |
https://www.fordbarn.com/forum/showthread.php?t=148555 |
#7 | |
![]() Quote:
Seems reasonable (the solenoid body itself is usually the ground), but why does it need a wire to the coil?
I'm making some up with Solenoid 240-01006 which has a button on it so if your under the hood you can just hit the button in the solenoid and not go to the inside of the car and hit the button. You can use the starter switch, but have to push the copper strip down with a bolt. I have it all worked out and working.
#10 | |
![]() Quote:
6v solenoids do not have the second small terminal nor a ballast resistor. If it was hooked up like the diagram in the link, you would definitely lose some smoke out of your wires.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 03-08-2021 at 08:53 PM. |
#11 | |
![]() Quote:
Not necessarily, depends on how the solenoid is wired internally. |
I seen a "No-Foot-Starter" advertise in latest Model "A" News.
#13 |
#14 |
Sure solenoids are used in many applications. But I would have to say that 100% of the solenoids I have seen in automotive starter circuits are as I described.
#15 |
I started doing the solenoid starter thing back in the late '50s on my '31 AA. I didn't have books, internet, or whatever, I just figured out how to do it myself.
That carried thru to today where I have a key start switch in my '31 pickup.
#16 |
Happy Camper here.
Thanks to all who responded to my post. I was able to use the information to successfully install a 6 volt solenoid on my Model A Ford Starter Motor. It works perfectly! Thanks again! |
#17 |
Thankyou all for that information. I really don’t wish to modernise my A but I’m not pedantic about it either. It’s just I continually get my shoe caught between the clutch and hand break, (my A’s are right hand drive). Where have you all placed the starter button or have you gone for an ignition/starter key?
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
#18 | |
![]() Quote:
#19 |
Guys, the foot starter switch is part of the whole Model A experience. It keeps all others guessing what the driver is doing leaning back and stretching out while the motor starts. It is one of the the only cars left on the road where your foot is turning on a 50 amp current to start the engine. I also own 1914 Model T and I can assure you that when that starter switch first appeared, it put smiles on the faces of a lot of people, especially in the winter time!! Ed
#20 | |
![]() Quote:
