Well Its not often I get let down but it wouldn't start at work ..clunk was all I got. Eventually it started and I drove home and knew something was not right it was running on 6 -7 cylinders, vacuum gauge was down and fluctuating.. After pulling heads this is what I found
looks like a crack in no.8 . I built and have been running this engine for about three and a half years..
"Came too close to dying to stop living now!" |
#2 | |
That's not the end to the day anyone wants. Is it repairable? Can it be sleeved?
Hoping for a speedy recovery, if its possible.
Sometimes, ingenuity gets in the way of sense and sanity. |
That's not good!
Yep - that would do it! Has had water in the cylinder for awhile - can see the rust pitting.
My guess is that you should be able to sleeve that one hole, put new rings on the piston and be good to go. Given that you had a starter "clunk", then you most likely had a lot of water in the cylinder and hydrauliced (sp?) the engine. I would have the rod for that cylinder checked for straightness and check the rod bearings. |
#6 | |
Might be dirt or something but it sure looks like a burnt exhaust valve in #5 cylinder.
And to me the overall condition doesn't look that great ether.
looks like the head gasket has problem at the rear water passage, the black areas usually are suspect places for leaks on that type of gasket
where is the suspected crack? ---is it the lower stud? ---how large is the bore> I don't think it is a crack most likely if it was cracked it would go all the way to the deck and over to the hole |
#9 | |
Personally I thought it would look better when I opened it up. I think the valve is fine . Used to get 21 -22 Hg at idle [with twin carbs] I could pull 60mph out of second easy., was a great engine but did spend most of its time in commuting.
#11 | |
Looks like a crack to me. You'll need to pull the motor down to sleeve it anyway, so I'd do a pressure test on the block - you'll then know for sure where the crack(s) are.
#13 |
That is sad.....
#14 |
do you have a armature growler? it can be used to magnaflux, and i used to use .001-.002 cuts on rotor lathe to make 'powder"
is it a blind stud hole? |
#15 |
A weak spot on 21 stud engines. Had one let go on a fresh rebuild. It distorted the top of the cylinder bad enough to lock up the engine.
#16 |
Rob , price some freight, I have a complete 24 stud 221 engine you could have.
and I second the look at the gasket, I had one just like it on the 33 the other month, the black areas specially. Lawrie |
#17 |
If it comes down to it Lawrie I will do thank you.
I need to take it out and assess it further , Ive been dawdling on the other [backup] engine so now I have to get the skates on and finish it so I can swap over , I still have not found 3 1/16 + .100 rings Keith dropped off a sleeve the other day so it could come in handy.
#18 |
get onto Hastings or grant for the rings.
Lawrie |
#19 |
Rob, I have some new model A engines coming over from Perth freight cost is very good, maybe not there other way.
And get a crack tester kit from Blackwoods and check it, but I think it will be the gasket. Lawrie |
#20 |
So the head gasket leaked into the cylinder and hydro locked causing the cylinder to crack correct? Had that happen once on a 428CJ.
