Old 03-01-2021, 10:58 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Which fuel fittings?
Originally Posted by jason78613 View Post
The connection from the copper fuel line to the newly installed gas tank in my '38 Ford standard has a small drip no matter how much I try to tighten it. I'm thinking the old fitting is no longer good?
I'm guessing it's the 2 piece with nut and ferrule, but want to make sure I order the correct one...Which of these two fittings is correct, and what are the different uses between the two?
https://cwmoss.com/products/fuel-lin...-piece-1932-48
https://cwmoss.com/products/fuel-lin...-piece-1928-29
Why don't you just remove the leaking fitting to see what you have instead of relying on someone else's guess.
