Old 02-23-2021, 03:35 PM   #1
61Klassic
Default Cold air plenum for carbs
Hi everyone.
I have a model A roadster with a full hood, running a healthy 293” flathead underneath with 3 97’s on a straight linkage.
The under hood temp can really get hot, surely sucking all this hot air into the engine can be no good for power?! However I’ve seen very few pics of lakes racers of old trying to scoop in cold air.
How would Stromberg 97’s deal with having a common plenum and having air forced in at speed?
I’m running a/f ratio meter so could monitor any lean conditions.
After any advice, thoughts?
61Klassic is offline   Reply With Quote
Old 02-23-2021, 03:52 PM   #2
jimvette59
jimvette59's Avatar
Default Re: Cold air plenum for carbs
Get a blower
jimvette59 is offline   Reply With Quote
Old 02-23-2021, 03:55 PM   #3
JSeery
JSeery's Avatar
Cool intake air always helps. In the 60s iced the intake before each run.
Old 02-23-2021, 04:11 PM   #4
61Klassic
Originally Posted by jimvette59 View Post
Get a blower
Thanks 🙄🙂 Not an option at the moment as I run normally aspirated in my class over here in the UK
Old 02-23-2021, 05:28 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Having a common plenum and the outside air forced in at speed would work fine. However if you were able to go REALLY fast then the forced now ram air would create a lean condition. This lean condition would crate more heat and possibly damage some internal parts if the top end charge was for an extended amount of time. The REALLY fast speed would be anything over 120 MPH the now ram air could add a slight amount of inlet pressure.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 02-24-2021, 01:16 PM   #6
61Klassic
Thanks Ronnie. I didn’t know if 97’s like having air pushed through them, some carbs don’t.
I know there is a possibility of running lean, but with a flatty running out of air high up the Rev range, but still having the correct jets to supply the fuel...?
As I said I have an a/f gauge hooked up to monitor running lean.
Old 02-24-2021, 04:13 PM   #7
61Klassic
No other opinions? I hope some old time lakes racers, Pete etc would have something to say?
Old 02-24-2021, 05:44 PM   #8
AnthonyG
AnthonyG's Avatar
I found the further / higher u get the carbs away from the engine the better for less heat & better performance! The sling shot intake is a great example, gets carb’s away from engine heat plus increases velocity & air intake potential. Lots of different variations available for raised intake setups that accomplish the same.
Nomad
AnthonyG is offline   Reply With Quote
Old 02-24-2021, 06:15 PM   #9
jrvariel48
jrvariel48's Avatar
get a blower
ditto!!
jrvariel48 is offline   Reply With Quote
Old 02-24-2021, 07:19 PM   #10
Ggmac
A one piece or original style with hinge ? My old street A ( radical sbc) I raised the rear center support 3/4” and used rubber bumpers on the curve . Just in front of the windshield is a good spot to get cool air . Itll take a bit to make it look smooth but it worked on my A in South Florida.
