Old 01-17-2021, 11:11 AM   #1
brum1
brum1's Avatar
Default Manifold Heater Mount
I acquired this manifold heater with the car. How do these typically mount to the exhaust manifold? This heater has two through bolts as shown in the picture? Appreciate any insight
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 01-17-2021, 11:38 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Manifold Heater Mount
Autolite heater manifold (waffle top style) is needed. It is secured with two small bolts through the top.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-17-2021, 11:40 AM   #3
KenBolton
It requires a heater mangold for it to fit over. Then the two bolts pass through the heater and screw into the manifold. The heater manifold I had was taller, more square and fluted than the standard manifold.
KenBolton is offline   Reply With Quote
Old 01-17-2021, 03:42 PM   #4
brum1
brum1's Avatar
Thanks Guys, Yes I have seen those waffle style, unfortunately my car does not have one at the moment
Old 01-18-2021, 12:18 PM   #5
AL in NY
AL in NY's Avatar
I believe the heater cover you have is used over the standard Model A exhaust manifold. The cover that goes over the Autolite waffle heater manifold looks like this.................
The heater cover you have goes over the stock exhaust manifold by removing the rear through bolt, then place the cover over the stock manifold, re-insert the bolt and tighten it to secure the cover.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-18-2021, 12:29 PM   #6
jack wingard
Al in NY is correct I have the exact same on my Fordor. No waffle heat exchanger. I have tough time with pics on this site or I would post.
jack wingard is offline   Reply With Quote
Old 01-18-2021, 03:56 PM   #7
brum1
brum1's Avatar
Thanks Guys, I will give this another look, if anyone does have a picture of this type installed that would be great
Old 01-18-2021, 11:15 PM   #8
Fred S
Fred S's Avatar
Here's mine...
Fred S is offline   Reply With Quote
Old 01-19-2021, 12:10 AM   #9
old31
Originally Posted by Fred S View Post
Here's mine...
Attachment 453301
Yikes, you really need that heater. You don't have any floorboards!
old31 is offline   Reply With Quote
Old 01-19-2021, 06:15 AM   #10
brum1
brum1's Avatar
Thanks Fred, what is securing the heater to the manifold(other than the hose)
Is your manifold a stock round body?
Old 01-19-2021, 10:23 AM   #11
Fred S
Fred S's Avatar
Yes my manifold is stock. The two halves of the heater fit around the manifold and are held together with two bolts.
