Old 01-12-2021, 12:51 AM   #1
65f100
65f100's Avatar
Default new to the model a/forum
just got my 29 pickup will do a preservation and make the truck road worthy - runs good starts rite up but carb leks out intake side while running needs brakes and steering help etc. - so far so good! im also on the h.a.m.b. under an alias as i didnt know they were connected - ill try and post a pic
65f100 is offline   Reply With Quote
Old 01-12-2021, 01:00 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: new to the model a/forum
Awesome truck! Welcome to the 'Barn'...
Old 01-12-2021, 01:43 AM   #3
McMimmcs
McMimmcs's Avatar
welcome to the barn! I also have a 1929 pickup. Hope you’re not too tall or heavy because there sure isn’t much room in the cab.
Old 01-12-2021, 08:32 AM   #4
rocket1
I also have a 29ccpu since 1961 a lot of enjoyment except for the drivers side spare a dog to get in and out now that I'm approaching 79 years.
rocket1 is offline   Reply With Quote
Old 01-12-2021, 08:41 AM   #5
77Birdman
Could always tie the spare to the radiator!
Welcome, great looking truck. My first 'car' was a 65 F100.
77Birdman is offline   Reply With Quote
Old 01-12-2021, 08:45 AM   #6
henry's 31
Welcome to Ford Barn. You have a very nice looking truck. Enjoy the ride!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 01-12-2021, 09:21 AM   #7
Chuck Dempsey
Chuck Dempsey's Avatar
Looks nice! Welcome to the barn....
Chuck Dempsey is offline   Reply With Quote
Old 01-12-2021, 10:32 AM   #8
65f100
65f100's Avatar
yes being 6' tall i find its easyer getting in and out the passenger side - plus that door opens and closes better!
Old 01-12-2021, 12:02 PM   #9
KenBolton
That’s a pretty straight ‘ol Pickup! Being 6’2” and a wee bit more than 230 lbs I was struggling to figure out how I would ever drive my ‘30 when it was done. I’d shortened the clutch and break peddles on my Coupe which helped a lot. I did the same with the pickup plus bent the shifter to the right an inch or so and tied the seat and backrest springs down as much as they would go. Now it’s reasonable although I still slide in butt first into the passenger side to get my legs in and out.
An alternative is to replace the seat springs with foam rubber but I wanted to have the vehicle judged at Oshkosh in Touring Class. Now, it the meet greet happens, that’s another issue!
KenBolton is offline   Reply With Quote
Old 01-13-2021, 02:10 PM   #10
rocket1
There are less thick seats available.
Old 01-13-2021, 05:39 PM   #11
Russ/40
Russ/40's Avatar
Amazing how these old machines keep coming out of the woodwork.
Old 01-13-2021, 06:23 PM   #12
McMimmcs
McMimmcs's Avatar
Please expound, where ?
Old 01-13-2021, 11:47 PM   #13
neds29
Welcome. Nice looking truck, hope you enjoy it. Where are you located? Ned
Retired civil engineer.
Winters in Phoenix, summers in Ipswich, Mass. and North Dakota.
'29 closed cab pickup- Excellent AZ truck.
'29 roadster- Owned for 21 years but now sold.
'28 CC pickup- My first car in Andover, MA back in '62- '63.
neds29 is offline   Reply With Quote
Old 01-14-2021, 10:18 PM   #14
65f100
65f100's Avatar
thanx for the welcomes - im having a blast working on this old truck doing the brakes and trying to figure out a pesky carb leak - leaks out the intake side of carb while running and i think ive traced it out to a sticky intake valve so its getting the MMO treatment - hope i can get it unstuck
ned im in New Mexico,Alamogordo
Old 01-14-2021, 10:40 PM   #15
frank mcdaniels
frank mcdaniels's Avatar
65f100 Welcome to the site, A stuck intake valve is not likely the cause of your carb leak even though Marvel mystery oil is ok . Your probably going to have to check out the carb. clean it set the float level make sure the float valve is working set all the adjustments and maybe with some luck it’ll quit dripping. good luck my first model A was a 29 pickup.
frank mcdaniels is offline   Reply With Quote
Old 01-14-2021, 11:04 PM   #16
Conaway2
Conaway2's Avatar
I and others would strongly suggest that you join your local MARC or MAFCA Model A club chapter. You will find other Model A owners who can provide lots of help and advice, if you want it. MARC - Model A Restorers’ Club; MAFCA - Model A Ford Club of America.
Conaway2 is offline   Reply With Quote
Old 01-15-2021, 12:47 AM   #17
CarlG
CarlG's Avatar
Snyder's makes the springs.
Alaskan A's
Model A Restorers Club
Mullins Owner's Club
Old 01-15-2021, 05:22 AM   #18
shew01
shew01's Avatar
Would these work?
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 01-15-2021, 11:37 PM   #19
65f100
65f100's Avatar
thank you for the advice Conaway2/frank mcdaniels i have joined a local club and they have been a help with the brake job - the stuck valve turned out to be an exhaust valve so ill keep at it till i get it - hope to have my truck on the road by the end of feb. - been having a good time with this piece of history im amazed at how easy every thing i put a tool to comes apart!
Old 01-16-2021, 12:48 AM   #20
old31
Best of luck with your new truck, and welcome to the forum.
Don't worry, if it didn't leak, didn't need better brakes, and didn't need help with the steering it would not be a Model A.
old31 is offline   Reply With Quote
