Seems I too have fallen victim and join in on a long list of souls who have run afoul of the mighty flathead gods.
The dreaded Ford "dole" nut fitting for the Holley 94 (not the hose barb variety) seems as elusive as a rainbow coloured unicorn. Digging though countless threads and sites and I still haven't been able to secure a source. Found the "correct" part - Weatherhead WH59X4 here and on HAMB, and thought I was golden when it showed up on the NAPA On-line store. No problem I thought, I'll go into town and visit the local NAPA store. We'll not so fast I was told. NAPA Canada is NOT NAPA USA. They could not even find the P/N in their system here. He was able to cross reference it with a Gates P/N, but none available in Canada! I think the Gates P/N is G49230-0404. I tried earlier in the day to see if Speedway had it as I was ordering some other stuff. Sorry sir, that P/N (WH59X4) does not show up in their system. Tried Third Gen Auto in Tennessee the day before, but they only have a barbed version which is no good for me as I want to use the 1/4" "copper" line I had purchased from them (Roy Nacewicz) last year. So, after getting back home, I hit the interweeb again, and thought I was on my way with the NAPA on-line site. Entered the qty (4) to my cart, shipping address (my US freight forwarder in Ogdensburg, NY), and was about to enter my payment information, but then a red message popped up saying that the min order qty was 10! What have I done to upset the flathead gods!? Is it because I decided to go with a stock intake and heads? Is it because I didn't buy Ron's book? Is it because I swapped a helmet dizzy for the crab dizzy? Between looking for what seems forever for my heads bolts, and now this, I think I must now make an offering to appease the flathead gods. I think I'll offer up one of my Holley 94's. Lol! But seriously, if anyone knows where I can buy this fitting, please let me know. I now need a drink or two, or three... |
Sacramento Vintage Ford has them also. #507-1 $2.25 for the special Ford nut and barrel. 1/2-20 unf with 1/2" wrench size hex. Order #507-2 for the same with a 9/16" wrench size hex head. $2.50
That is great, but Charlie ny will send a few up to me. If my barn find cobbled up Holley 94 fails to perform, I'll be sending it down to him for a proper rebuild.
#5 | |
![]() Quote:
The only local dealer I have found in Canada is George Moir in Alberta but hasn't had anything in stock that I was after. He does carry Drake and Carpenter stuff. The only other place useful was Carburetor doctor in BC who was able to supply me with a Dayton parts rebuild kit recommended by Charley ny. I ended up getting fuel line fittings and pre bent copper coated steel line from 3rd Gen auto. Copper fuel line: take a search thru the threads. Cooper is not recommended, best to go with copper coated steel if that's the look you want. I've heard horror stories but never experienced myself, although there was a copper line on my flathead for the first 4yrs I owned it. |
This little puppy! |
Wait, it gets better...
It's too short! Haha! No problem, I have 10' of the copper line I ordered to play with. |
Wait, it's still not over. So I pull the copper line out of the plastic bag to take a pic so I can post it, and guess what? Two more fittings included! I'm a colossal idiot of epic proportions! The flathead gods are NOT happy with me...
#9 | |
![]() Quote:
At least you've got that extra material to play with. With that too short fuel line, you could always cut it and add an inline fuel pressure gauge . |
I'm laughing out loud here, Ziggster. Glad you're sorted.
I always use the Kunifer cupro nickel tube. To be honest I prefer the separate nuts/ferrules. The one piece ford nut combos don't seem to work as well for me. All the best. Mart. |
Mart,
I agree, the combo nut and ferrule can be a pain. For it is worth I always seat the ferrule on the tube using a machined female brass fitting.....never attempt to seat the ferule in the fuel inlet of a 94 airhorn. Zig, Do you still need three of everything ? Charlie ny |
Ziggster. If you have a tubing bender, it is fairly easy to reshape the line you have shown in post #7. I had to do that for the new line I put on '46 Coupe
#13 |
You might be right Will, as I have the aluminum intake. Not sure if it is higher than the "stk" C59A cast iron intake. My engine is covered up due to proximity of my blast cabinet, and I do not want to uncover it until I'm done blasting, and have cleaned up all the dust etc.
Charlie, I'll still take three of everything if you don't mind. Still not sure what fuel fitting is better. The Ford fitting seems loose on the inlet to the carb. Loose as in terms of the external threads and how they mesh with the female threads on the carb inlet, and between the tube OD the nut ID. Of course I do not want to tighten anything down too much. What do you recommend as I have two of each? |
#14 |
51woodie, I do have a cheap generic plumbers tube bender. I tried it on some cheap copper tubing I picked up at Home Depot and the tube was crushed as it was bent. I recently saw a vid by Hot Rod Hippie where he had a very nice tube roller to straighten out coiled up tubing. Here is one from Eastwood, I had never seen one before!
#15 |
Zig,
Okie dokie.......the loose fit could be from years of over tightening .The carb material is a bit cheesey. Charlie ny |
#16 |
Tape one end shut. Fill with fine sand, salt will work, tamp, fill, etc. When absolutely full, tape the tube shut. Then, bend away...no kinks. I've done this many times with copper, stainless, and aluminum tubing. Recently did it to bend a goose neck in 1/2" stainless tubing for a bench light I made with a y-block valve cover for a shade. Once full of sand, I used a manual conduit bender, again no kinks.
As to copper tubing, I understand it is vibration that causes work- hardening and cracks. If there is that much vibration between a fuel pump and carb on a flathead, I suggest snugging both down so they dont move around anymore. YMMV.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 12-25-2020 at 12:19 PM. |
