Old 12-18-2020, 02:54 PM   #21
dmsfrr
dmsfrr's Avatar
Default Re: Is anybody
We got 3 or 4 inches of snow a couple weeks ago. So I shoveled the front sidewalk to be nice.
Old 12-18-2020, 05:27 PM   #22
58Yeoman
58Yeoman's Avatar
Barely covered the ground here a day or two ago. Didn't even get to use my 'new to me' JD with plow yet. Snowblower is still hanging on the wall.
58Yeoman is offline   Reply With Quote
Old 12-18-2020, 05:43 PM   #23
yblock57
yblock57's Avatar
Originally Posted by dmsfrr View Post
I was almost stuck under a '57 Bird dashboard...
trying to take it out without removing the steering wheel or column.
I know how you feel! Pulled the speedometer out of mine without pulling the seat. It's very tight under there.
That is one pretty dashboard. Is that parchment or white?
Kent — Round Rock, TX
'56 F-100 | '56 Crown Vic | '57 Fairlaine 500 | '57 Thunderbird
yblock57 is offline   Reply With Quote
Old 12-18-2020, 10:39 PM   #24
dmsfrr
dmsfrr's Avatar
Thank you but it's my wife's fault. She wanted a yellow T-Bird with a white interior.
The catalogs call it white but it's probably more like Parchment or maybe a dark-ish version of Ivory. It's enough darker than the couple year old bright white paint on the lower dash that it bugs me, especially where the vinyl arm rests on the doors line up with the lower dash. I'll be repainting that metal to more closely match the vinyl.
The dash cover is only a few years old, put on by the last owner, back to the original color like the rest of the car.
As pretty as it looks, the glare from the white dash onto the inside of the windshield can be fairly tough to see thru, so I'll be getting a black dash mat to put up there while driving.
I ended up pulling the steering column to have enough room to slide and lift the dash out by myself. Lots of surface rust on the drivers side firewall and the insulation pad has disintegrated, but that's why I'm taking it apart. More cleanup work left to do...
Old 12-19-2020, 01:34 PM   #25
yblock57
yblock57's Avatar
That’s a big job! Results will be worth all the hard work. Good luck.
Old 12-20-2020, 09:30 AM   #26
CSPIDY
CSPIDY's Avatar
As viewed by the picture which may not show the real look, the contrast between the dash pad and lower dash paint looks nice.
CSPIDY is offline   Reply With Quote
Old 12-20-2020, 10:20 AM   #27
dmsfrr
dmsfrr's Avatar
You're right, it looks better in the photos. It could be the fluorescent lights in the garage. In natural light the white is a bit intense, I'm just going to tone it down a bit. The previous owner repainted it and may have used a slightly different color than original.
Old 12-20-2020, 01:07 PM   #28
HOTRODPRIMER
HOTRODPRIMER's Avatar
Originally Posted by Ford Freak View Post
I have never understood why there is not more folks w/'54 & up FoMoCo products on here . There sure is over on The HAMB site !
Like Paul I poke my head in from time to time and I have a '54 Ford and am the Administrator of the '54 Ford Club of America and a member of the Hamb.
The Ford Barn is feared more to the original cars, I too am a hot rod guy and there is a later model V8 Ford engine under the hood along with a 5 speed transmission. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
