Old 12-09-2020, 11:05 AM   #6
mfirth
Default Re: BorgWarner Overdrive Questions
I would never pull the handle out while driving. Not good . you can push it in to put the car in overdrive anytime. I also use a toggle to turn the o/d system on or off...allows you to "kick down" without flooring the throttle.....and times 2 on what Frank Miller said.
mike
mfirth is offline   Reply With Quote
