12-05-2020, 09:07 PM | #1 |
Generator question
We have an AA truck in the shop for repairs. The pulley on the generator had screws(4) holding the pulley together. When I went to remove the pulley, the main shaft in the generator pulley forward about 5/8". It moves back and forth. Anyone have an idea of what the problem might be before we look harder?? Maybe like a front main bearing??
Bob from Northport Northport, Michigan |
12-05-2020, 09:38 PM | #2 |
Re: Generator question
Hi Bob -
You didn't mention what year generator, but there should be a retaining ring on the generator armature shaft that stops the armature from moving forward. See attached drawing - part callout 20 |
12-05-2020, 10:14 PM | #3 |
I appreciate the drawing. The AA truck is a 31'. I think the generator is original to the truck. 31 generator. The retaining ring is on the shaft and is visible when the shaft comes forward
12-05-2020, 10:17 PM | #4 |
Here is a photo
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
12-05-2020, 10:21 PM | #5 |
Bob -
There are two retaining rings... another identical to that one sits directly behind the front bearing, locking the front bearing to the armature. Look again at the drawing I attached and you will see the rear retaining ring.. also part number 20 The bearing is held captive in the front end plate by the bearing retaining plate. |
12-05-2020, 10:22 PM | #6 |
12-05-2020, 10:25 PM | #7 |
Those rings are not spring steel.. just a maleable ring. It very likely just came out of it's groove and slid backwards.
12-05-2020, 10:43 PM | #8 |
Shims are offered to remove end play in the armature shaft , I think that Bratton offers them . I used them when I overhauled my generators and starters .
12-05-2020, 10:53 PM | #9 |
GRutter has got it. You will need to pull generator apart and replace or re-install that inside #20 retainer. My rebuild kit came with external split rings but I thought the original c clips fit better after I squeezed them together a bit.
12-05-2020, 11:32 PM | #10 |
Thank you all very much. We'll see on Monday
12-08-2020, 05:20 PM | #11 |
Mr Rutter and others. You were right, The inner ring was not there. Apparently broke into pieces or fell away. I will order parts tomorrow. Thank you again!!!
