Old 09-25-2020, 05:13 PM   #21
42merc
42merc's Avatar
Default Re: Winfield su1a
I ran a Winfield R1 in a 59A 60 years ago.
The idle was smooth as the stock cam.
A real Winfield, not a copy. A stock 8CM or EAB cam would probably perform better.
42merc is offline   Reply With Quote
Old 09-25-2020, 05:16 PM   #22
Marmon4x4
Marmon4x4's Avatar
I think I may use the R1. Unless I hear something else to persuade me otherwise. Thanks for all the help!!!
Marmon4x4 is offline   Reply With Quote
Old 09-25-2020, 05:17 PM   #23
Pete
You are right about that..LOL
Old 09-25-2020, 05:19 PM   #24
Tim Ayers
I'm so sad to hear this. Winfield is held in such high regard. I wish the cam would have preformed better.
Old 09-25-2020, 05:33 PM   #25
Marmon4x4
Marmon4x4's Avatar
While digging through the internet I found a book with a bunch of old original cam specs! The book is “ How to build Ford flathead power” By George McNicholl. Has several different grinders. It seems the R1 is Windfields full race grind, and it doesn’t match what is on the cam card that Isky gave me back when I sent my cams to them. Mine might be a bad copy. Can you imagine that!
Old 09-25-2020, 05:33 PM   #26
Pete
Winfield had the cams to have for flathead 4 bangers in the 20's and 30's and he did most of the winners for the Offy's but he was always way behind with the flathead Ford V8's.
The Isky 404, one of the most successful flathead circle track cams ever made was an almost direct copy of the Winfield #4 Offy grind.
Old 09-26-2020, 10:06 AM   #27
42merc
42merc's Avatar
Winfield's R1 cam was always advertised as a "3/4 Race" cam.
Much has been lost in translation over The last 50 years.
Old 09-26-2020, 11:56 AM   #28
Tim Ayers
Pete
Not to stray too far off topic, but does the #4 grind need radius lifters like the 404?
Old 09-26-2020, 01:44 PM   #29
Pete
Originally Posted by Tim Ayers View Post
Pete
Yes.
Old 09-26-2020, 05:46 PM   #30
Offy 220
Offy 220's Avatar
Yes.
Pete's correct! I put together an Offy 220 in the mid 80's with #4 Winfield camshafts. They use radiused cam followers which slide over the valve and spring assembly that ride in keyed bore. The valve lash is adjusted by filing the valve stem with a "Filing block" or if the clearance is too tight the valve seat is ground. All of this takes a considerable amount of time since there are four valves per cylinder. Also, grinding the valve seat requires a "small sized" Kwikway or Sioux grinder since the cylinder head and block are "one casting" [non removable cylinder head] which is done though the bottom side of the block. I still have the Offy filing block.
Offy 220 is offline   Reply With Quote
