#41 |
You can use .030 or .035 both will work fine.
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#42 |
I gap at .025. Years ago I used a wider gap. Have a crab distributor and would have problems with carbon tracking in the cap. Probably poor cap quality. Tried several different brands, same thing. Dropped to .025 and have never had a problem since.
#43 |
So for my stockish 36 flatty 21 stud what p/n ngk's and what gap Gents?
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
#44 |
I use .025" as my experience is the same as flatjack9.
#45 |
As the gap is increased the energy that the coil outputs increases. At some point the coil output can exceed the insolating properties of the system. Because the of compression, most flatheads do not require that much spark energy.
#46 |
When I put the NGk plugs in my 51 EAB stock engine, they ran very well for a few miles. Now I am getting a "fuzzy" carbon build up on the plugs causing power loss. What gap are you all using? What else would you suggest I check out? Thanks in advance for the help. |
#47 |
I have electronic ignition and run .028 with NGK plugs
"Came too close to dying to stop living now!" |
