Old 09-14-2020, 04:03 PM   #1
safeguy150
Default NGK Plugs
Anyone using NGK plugs in an 8BA? if so any pros or cons?
safeguy150 is offline   Reply With Quote
Old 09-14-2020, 04:21 PM   #2
jrvariel48
jrvariel48's Avatar
Default Re: NGK Plugs
I'm using NGK's in my blown flathead with excellent results. They were recommended by some well known people here and so far so good. My 2 cents.
Joe
jrvariel48 is offline   Reply With Quote
Old 09-14-2020, 04:45 PM   #3
cadillac512
cadillac512's Avatar
Me too. B6L in an 8BA style Merc slightly "warmed up". Plugs look just right. Milled 8CM iron heads.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-14-2020, 04:59 PM   #4
42guy
42guy's Avatar
I have been using them for 15 yrs.
42guy is offline   Reply With Quote
Old 09-14-2020, 05:18 PM   #5
Jockeyshift41
Jockeyshift41's Avatar
B6L’s working good with my EAB heads.
Al
Jockeyshift41 is offline   Reply With Quote
Old 09-14-2020, 06:06 PM   #6
adileo
adileo's Avatar
Echo that!
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 09-14-2020, 06:12 PM   #7
Tim Ayers
Get them for Rock Auto for under $2.00 a piece
Old 09-14-2020, 06:13 PM   #8
wga
wga's Avatar
Used for the past 15+ years in my 49
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 09-14-2020, 06:16 PM   #9
GB SISSON
GB SISSON's Avatar
Lots of positives! Same plug you'd recommend for a stock 221?
Old 09-14-2020, 07:12 PM   #10
flatjack9
flatjack9's Avatar
Yes
Old 09-14-2020, 07:14 PM   #11
Talkwrench
Talkwrench's Avatar
Work fine on my 21 studder...
Old 09-14-2020, 07:17 PM   #12
uncle max
uncle max's Avatar
NGK's are one of the only plugs where the electrode is indexed to the threads, if that means anything... I like 'em.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 09-14-2020, 09:41 PM   #13
19Fordy
19Fordy's Avatar
I use the NGK GR4 2635 plugs recommended by Mark Kirby when I bought his heads in 1999.
Work fine.
Old 09-14-2020, 09:50 PM   #14
GB SISSON
GB SISSON's Avatar
Thanks guys! I am learning the value of a well tuned ignition system from the slot in the end of the cam to the tip of the spark plugs.
Old 09-15-2020, 12:14 AM   #15
Aarongriffey
The gold color on the threads is something sprayed on to help keep the plugs from sticking to the head so you can never strip the threads when removing the plugs. They break loose easier that way.
I just started using NGK plugs in 1972.
I installed NGK plugs in my F1 in 2006 and again in 2016.
Aarongriffey is offline   Reply With Quote
Old 09-15-2020, 06:29 AM   #16
oldbugger
oldbugger's Avatar
Joe
Maybe thats why your bolt is falling out
oldbugger is offline   Reply With Quote
Old 09-15-2020, 07:27 AM   #17
V8 Bob
V8 Bob's Avatar
Yes, B4L (3112) in my roadster.
Old 09-15-2020, 07:57 AM   #18
19Fordy
19Fordy's Avatar
Won't hurt to add a dab of anti seize.
Old 09-15-2020, 02:13 PM   #19
1931 flamingo
1931 flamingo's Avatar
When RONNIE ROADSTER had my 40 this Spring that's what he installed. Runs great.
Paul in CT
Old 09-15-2020, 03:55 PM   #20
GB SISSON
GB SISSON's Avatar
Why B4L and not B6L?
