Old 09-14-2020, 01:09 PM   #5
52 Ford
Default Re: 6 volt Generator in 12 volt system
Yes I will be using a 12 volt battery.
So I can use the 6 volt starter relay?
I need a new coil anyhow the top terminal broke off when i took it apart, so should i just get a new 12 volt coil?
52 Ford is offline   Reply With Quote
