Trying to install cam into block, cam is a Kiwi 100 from Tony. Cam bearings were installed at machine shop. Did not have cam when bearings were installed. Oiled bearings and journals for test fit. The cam would not slide in. The journals measures 1.797 and the cam bearing measures 1.794. I know obviously I need to go back to machine shop, any other advice? As always thanks in advance.
#2 | |
![]() Quote:
Phil NZ |
My first reply misread Phil's reply, so I deleted it. I think I recall a thread about some cam bearings being incorrect. Go a Google search and include Fordbarn in the search line for it will bring up an threads on the topic from this site.
I would try a different set of cam bearings.
Seen this many, many times over the years, sometimes a customer will assemble the entire short block and THEN try the cam, really, really bad idea! Since Tony is doing regrinds it's likely NOT the cam, but some where more in the brgs themselves OR the hole sizes in the block?? (Add) Take this as a "tip", the very first item to check when the job is delivered is the cam fit! We try a cam in EVERY block we do BEFORE it ever leaves the shop, this is "etched-in-stone" here! Thanks, Gary in N.Y. P.S. Most of these Flatheads have their cam holes on the "larger" side of the dimension, this is NOT a "backyard" fix here, it should definitely go back to the shop that installed them!!
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 08-25-2020 at 05:09 PM. Reason: C |
1st: Make sure you mic the cam journals before you order cam bearings - have seen guys with .010 cam journals (and they didn't know it) - with STD bearings in the block. Cam goes in really easy . . . then wallows around . . . as you see low oil pressure and wonder why.
![]() 2nd: Before you even put the bearings in the block, check to see if they are the correct size and slide onto the cam journals . . . should be a nice slide-on fit. Sometimes one has to hand polish the bearings once they are installed - as somebody managed to 'nick' them upon assembly . . . have seen this many times. I realize this should not have happened . . . but it does. A little ScotchBrite and some solvent . . . cleans things right up. Third: If you're going to be running a mechanical fuel pump, make sure the rear cam bearing is correctly installed and that you can drop the fuel pump pushrod in and it goes through the cam bearing. Have seen folks put the cam bearing in wrong - never checking the fuel pump push rod . . . owner gets it home, puts his nice shiny new performance intake on it, tries to put in the fuel pump push rod . . . and it won't drop down. Whups! Time to tear the whole engine back down . . . yikes! |
Spec on the cam journal is 1.796 - 1.797, so your cam is not the problem.
Machine shop said bearings were bad and are correcting issue, thanks for all responses.
