Old 08-19-2020, 10:01 PM   #1
Sheldon Paulger
Default Keyed 6 volt source
Has any one come up with a way to have 6v switched on and off by the ignition key?
Sheldon Paulger is offline   Reply With Quote
Old 08-19-2020, 10:23 PM   #2
1930-Pickup
Default Re: Keyed 6 volt source
Are you talking about an original type pop out switch?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 08-20-2020, 07:29 AM   #3
eagle
eagle's Avatar
If you have an original cutout, you can tie to the input side. It'll only have power when the car is running. Depending on what you plan to use the power for, filtering and conditioning may be a good idea.
Old 08-20-2020, 07:47 AM   #4
Badpuppy
Would be good to know what it is you're trying to do.
Wiring is from points - switch - coil - battery. (Coil is live at all times.)
If you want to change to switched battery go points - coil - switch - battery. I recommend a fuse.
Old 08-20-2020, 09:22 AM   #5
Sheldon Paulger
Thks for the reply. I originally connected to the input side of the gen cut out, but there is insufficient voltage until about 800-1000 rpm. If possible, I'd like to have an ign key source.
Old 08-20-2020, 09:35 AM   #6
ryanheacox
ryanheacox's Avatar
Nu-rex makes a popout lookalike with a keyed accessory terminal. https://www.nurex.com/pop-out-look-a...ssory-terminal
Old 08-20-2020, 10:38 AM   #7
Ruth
I wired mine battery+ - switch - coil - points - ground. I'm 12v neg ground.
Ruth
Old 08-20-2020, 03:54 PM   #8
kenparker
kenparker's Avatar
Are you running an original or original style popout switch??? ken
kenparker is offline   Reply With Quote
Old 08-21-2020, 09:47 AM   #9
Curtis in MA
What wires do you switch to get the switch before the coil and points?
I have original 6v wiring.
Curtis in MA is offline   Reply With Quote
Old 08-21-2020, 09:56 AM   #10
Patrick L.
Patrick L.'s Avatar
I guess you don't with original pop-out. With an aftermarket normal type switch its easy. Its just terminal box to switch to coil - [ if + grd] then coil + to distributor.
Old 08-21-2020, 10:01 AM   #11
Ruth
Someone posted this schematic for rewiring ignition switch in order to use an electric shut-off switch. As stated, you can't do this with a Pop Out.
Ruth
Old 08-21-2020, 11:34 AM   #12
Curtis in MA
thanks. Just went out and did it. Took it for a test drive and all went well.
Old 08-21-2020, 06:17 PM   #13
Sheldon Paulger
my car has the armoured cable coming directly from the ignition switch---this must be the pop out ign switch (although is does not pop out, the cylinder that the key fits into does protrude sits out beyond the face of the instrument panel.)
I went inside the dist and brought a wire outside from the connection at the armoured cable. Engine dies when I connected a LED load. Maybe I need to install a diode to prevent leakage back from the points/condensor??
Old 08-22-2020, 06:33 AM   #14
Patrick L.
Patrick L.'s Avatar
Just follow the diagram.
