After thousands of dollars and several hundred hours over the last year my car is begging to be a hot rod. Drover to work yesterday with no problems. And as I was leaving work to come home 500 foot down the road she died without a sputter. This has happened a number of times over the last year and it's always been something different. I just think it's funny how much she's begging to be a hot rod. I'm scoping out of 283 right now and I think it will fit perfectly. :-)
Really?
![]() ![]() you don't have to leave the reservation.. |
#5 | |
![]() Quote:
David Serrano |
Proper restoration to original specifications eliminates the need for modifications in most instances, a lot of reproduction parts don't meet original specifications, its not about how much you spend, it's more about the details of restoration |
Model A's were far from being perfect . There are several improvements that don't show that can be made .
We used Model A's as daily drivers back in the '50s. The only time I had a problem was when the rubbing block on the points wore down and the car was only running on one cylinder.
This problem was not the car's fault, it was caused by lack of maintenance.
#9 | |
![]() Quote:
I have truck resuscitated after a 50 year storage nap. To make a daily driver needed a lot done to be reliable. |
#10 | |
![]() Quote:
From my experience , a higher compression head will make a world of difference in hill climbing and overall performance .
#13 |
I run dual model B carburetors on my roadster and my speedster with old aftermarket cast iron intake manifolds . More carburetors or a larger carburetor will help . I prefer to use updraft setup . Updraft won't give as much flow as dual down draft but has the cool look and doesn't flood as easily as downdraft setups can . I can drive them on the street the same as the original setup .
#14 |
Two updrafts better than one updraft
One downdraft better than two updraft Ever wonder why a stock a makes a sucking sound when revved up?..not enough fuel,like sucking a milkshake with a cocktail straw |
#15 | |
![]() Quote:
Sorry Purdy, was not questioning your info, from your previous posts I know you know your stuff. Was just trying to add to the conversation for possible others that improvement in one area can cause problems in other areas, and to mention that additional performance gains can be made with carburation. Last edited by 30 Closed Cab PU; 08-14-2020 at 12:14 PM. Reason: typos |
#16 |
Free flowing exhaust and warmer ignition helps . The spark comes from the coil . Hotter coils are available that look no different from any other replacement coil . I run the Pertronix flame thrower coil . More gap at the rotor tip will give hotter spark . I run a gap of thirty five thousands at the rotor tip . I get instant starts and power that can actually be felt .
#17 | |
![]() Quote:
Purdy- I think I have had an "Aha" moment . Will be going off topic so am starting a different thread on the Pertronix coil. Last edited by 30 Closed Cab PU; 08-14-2020 at 12:41 PM. Reason: typos |
#18 | |
![]() Quote:
No problem, your input is true and welcome . It can be really easy to go too far with modifications . Too much carburetion can be a common problem with dual downdraft carburetors . Some modifications need other modifications to be of benefit . No modifications are necessary for the original, model A , its a matter of personal choice . I'm just sharing a few of the modifications that has worked for me over the past sixty years . |
#19 |
DannL Take a look at some Model As that have been hot rodded. There is a lot more to it than just dropping in a V-8. Updated brakes, steering, rear end trans, etc, Sell your current Model A and buy a hot rod. Most are for sale for less than half what they cost to build.
#20 | |
![]() Quote:
