#21 |
I've seen two styles (1st & 2nd below)but I haven't seen that one. The 1952 chassis part book lists 3 different types.
1st 8CM-9600-A1 description: Air cleaner and silencer assy (oil bath)-without elbow-special equipment- repl by (1) 8CM-9600-A5 and (1) 1CM-9663-B brace 2nd 8CM-9600-A5 description: Carburetor air cleaner assy (oil bath) -with elbow 3rd 8CM-9600-B3 description: Air cleaner & silencer assy (dry type)-replaced by 8CM-9600-A1 The last one is only listed for 1949. I wonder if the one previously pictured in post #18 is the dry type as described in the 3rd item? You don't see that one much. |
#22 |
Hence why I put "Sidedraft" in quotes. I know it's not a sidedraft, but lots of guys call it that.
#23 | |
![]() Quote:
This is another one I have in the process of opening up the intake port.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-01-2018 at 06:11 AM. |
#24 |
Well lots of good discussion. I think I’ll hang on to my 885. It’s all ready rebuilt who knows maybe set up a manifold with a pair of them on it!
Sent from my iPhone using Tapatalk |
#25 |
I have seen two of those manifolds on eBay. One was a $475 "Buy it Now" and it sat for a couple of months but finally sold. The other was an auction that IIRC, went for a little less than that. I think they would be a bit much for anything but a big inch engine with a bunch of mods.
#26 |
#27 | |
![]() Quote:
#28 |
I'm not sure they rated them in CFM back on those days. The venturi size was still the most common way to rate them. The Lincoln EL types were made for the 337 engines and had the 1 5/32" venturis. The ones for the big trucks were likely the same size as Lincoln but they had a governor. The Mercury CM types had 1 1/32" venturis so they would've had less flow.
CFM is likely from 170 to 205 on the two sizes. Last edited by rotorwrench; 03-02-2018 at 12:40 PM. |
#29 |
Here is my 885fg off of my 337 Flathead. It was a truck motor, so it had a governor. I changed the dizzy to a lincoln car dizzy so I am going to change the 885 base to a non-governed one. Therefore the carb is incomplete, but is rebuilt and powder coated to be “different”!
![]() Sent from my iPhone using Tapatalk |
#30 |
I had Charlie NY rebuild my 885 a couple of years ago, and this year it's accelerator pump or something in that area is not right, so I am going into it to see if I can find the problem. I ordered a kit from one "Carb Doctor" a week or so ago, have not seen it yet , but if it is complete, will go into it.
#31 |
Back in l954 I put a Merc intake and the Merc carb on my '49 Ford. It was a side draft carb but I don't remember the model number. But I do remember something about it.
It didn't help the speed and I change back to the stock setup after a few trial runs. Sorry for the double repay! Last edited by JT FORD; 08-13-2020 at 01:53 PM. |
#32 |
I tried this Merc intake and carb in '54 on my '49 Ford car. It didn't increase the speed and I soon removed it and went back to stock setup.
