Old 08-06-2020, 10:09 PM   #1
Brendan1959
Brendan1959's Avatar
Default Main bearings Babbitt unusual
I pulled down one of my spare motors the main bearings are different to my other motors. Machined groves in the block bearings and none in the caps?
Is this unusual?
Brendan1959 is offline   Reply With Quote
Old 08-06-2020, 10:22 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Main bearings Babbitt unusual
Although that is not my favourite way of doing it, I've seen bearings like that go for a long time. It is clear that those are not new bearings and that they haven't been a problem so far. The oil flows around the bearing through that groove till it gets to the join between the block and the cap. You'll notice the edges there are chamfered almost right across the bearing. The oil runs along there so you have lubrication right across the bearing surface. More oil on one side than the other but adequate.
That's fine on the front and middle bearing but I like a spiral groove in the rear one to get the oil across the bearing better.
You can add the groove in the top half now if you like.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 08-06-2020, 11:21 PM   #3
Jack Shaft
Those bearings will work well,oil is carried through the bearing by hydrodynamic theory and the turning crankshaft,the crankshaft is supported by a thin filmof oil,which flows as the crankshaft turns.
Old 08-07-2020, 04:46 AM   #4
Werner
Werner's Avatar
Brendan,
I can't say that specifically about the A motor. But in the past it was generally thought that there should be a groove in plain slide bearings in order to transport the lubricating oil.
It was later researched that these grooves disrupt the hydrodynamic lubricating film. Therefore, sliding bearings without a groove in it are used nowadays. That's better.
Perhaps because of this someone used more modern bearing caps on your engine?
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-07-2020, 11:01 AM   #5
Jim Brierley
Looks like that block was set up for full pressure oiling, with a drilled crank for oil to the rods.
Old 08-08-2020, 12:02 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
My thought as well.
Old 08-08-2020, 01:26 AM   #7
Brendan1959
The crank is not drilled, I am hopeful this block can be used with these bearings, its a shame the crank has a little rust and some minor pitting, I think this one was stored outside for a while. I have a couple of cranks, perhaps one can be ground to fit. I only have a vernier, so I have ordered a micrometer so I can measure properly. The last picture of the rear-main almost looks like an insert.
The rods have a similar grove, but in the cap and rod.
Its got one x rod as well.
Jim
I have your book and have read it again while in isolation, a good read.
Brendan
Old 08-08-2020, 05:39 AM   #8
Synchro909
Synchro909's Avatar
Some minor pitting on the journals won't do any harm. They act as an oil reservoir. The journal and the babbit should never come into contact with each other anyway.
Old 08-09-2020, 01:58 AM   #9
Brendan1959
https://www.youtube.com/watch?v=a8mx...ature=youtu.be
https://www.youtube.com/watch?v=6k3o...ature=youtu.be
Thought I would try cleaning up the crank in my lathe.
Old 08-09-2020, 10:45 AM   #10
Russ/40
Russ/40's Avatar
Originally Posted by Brendan1959 View Post
Clever approach, very high tech, and very functional. LOL
Old 08-10-2020, 02:04 AM   #11
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Don't turn it in your lathe, just polish it with crocus cloth if the journals are round
Richard in Anaheim CA is offline   Reply With Quote
Old 08-10-2020, 06:38 PM   #12
Brendan1959
After cleaning up the crank i tested with plasti gauge front and center 2 thou, rear about 6 thou.
Block seems standard size ( I have a bore gauge coming).
I have also ordered a Lisle micrometer hone. Apparently they work well and can hone to next oversize.
Old 08-10-2020, 06:49 PM   #13
Synchro909
Synchro909's Avatar
Have you considered taking 4 thou worth of shims out of the rear bearing and calling it good?
Old 08-10-2020, 08:34 PM   #14
Brendan1959
That is the plan!
Old 08-17-2020, 09:27 PM   #15
Brendan1959
Modified dipper pan, I wonder what made them do do this?
Old 08-17-2020, 10:56 PM   #16
Synchro909
Synchro909's Avatar
Over the years, there have been all sorts of screwball ideas about how to improve the dipper tray. That is no doubt one of them. I've even seen holes drilled in the bottom of the tray. I think that was done so that ALL of the oil would be removed when the sump is drained for a service and no old oil will contaminate the new. Pity about the big ends running dry on every start up!
Who knows what they were thinking. I'd just weld up those holes and use that tray.
Old 08-18-2020, 02:23 PM   #17
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Look again. The holes are not affecting the oil levels in the dipper sump. Whatever amount of oil that was in the sump when the engine stopped rotating is the level that would have been there during start-up. Therefore the rods would not have been dry when the engine was started.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-18-2020, 09:05 PM   #18
Synchro909
Synchro909's Avatar
Brent, my comment was referring to the example I had just given about holes in the bottom of the dipper tray - not the ones in the picture. With holes in the bottom, the oil drained out very quickly so the rods ran dry till oil filled everything up again.
Old 08-18-2020, 10:16 PM   #19
johnneilson
Or they just stopped turning................
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
