Old 08-07-2020, 09:04 AM   #1
Conaway2
Conaway2's Avatar
Default Torque Tube Bolts
Still rebuilding the rear axle, and ran into a couple of questions yesterday when I disassembled the banjo and torque tube. 5 of the 6 bolts appear original, in that they have holes for safety wire and have a shoulder just below the bolt head. The 6th bolt had no hole and also had a lock washer.
My questions -
Were lockwashers used on these bolts ?
Do these bolts have the special thread pitch like the axle housing bolts do ?
Were these bolts plated or painted when new ?
Many thanks
Jim
Conaway2 is offline   Reply With Quote
Old 08-07-2020, 02:33 PM   #2
Kevin in NJ
Default Re: Torque Tube Bolts
No lock washers.
Like most of the chassis threading they are tight tolerance so they should have limited play.
Also no gasket. The tube is also the bearing stop for the pinion bearing shell.
Do not forget to use a flat file on the mating surfaces. Not hard, just to locate any high spots and bring them down level so the flanges can mount tight.
Old 08-07-2020, 08:38 PM   #3
Conaway2
Conaway2's Avatar
So no gasket between the torque tube and banjo ? Why do gasket sets include one ??
Old 08-07-2020, 11:55 PM   #4
Tom Endy
Tom Endy's Avatar
From what I have read Ford did not originally put a gasket there. However, it is a source of an oil leak, so a lot of people put one there. The Mitchell overdrive company provides one with their overdrive kit. All the suppliers carry them. I always put one there.
Tom Endy
Old 08-08-2020, 12:11 AM   #5
Tom Endy
Tom Endy's Avatar
Over the past 35 years while rebuilding rear axle assemblies I noticed that the safety wire applied to the six torque tube bolts was all kinds of ugly. None were ever found done like an aircraft application. I decided early on that when I finished up a rear axle assembly it was going to appear neat even it it was not according to Henry. Having acquired a good supply of original torque tube bolts, I use them such that each bolt is a trial to see that when properly torqued the safety wire hole is parallel to the flange. It takes more time, but when I am finished I think it looks better than when found. It has become my trade mark on all rear axle assemblies I overhaul.
Tom Endy
Old 08-08-2020, 09:43 AM   #6
Conaway2
Conaway2's Avatar
Tom - thanks for your comments. I like your approach to installing the safety wire - will try it myself when I get to that stage.
Old 08-08-2020, 11:02 AM   #7
Russ/40
Russ/40's Avatar
That extra care you take, is much appreciated by us guys that notice it.
Old 08-08-2020, 11:40 AM   #8
Tom Endy
Tom Endy's Avatar
Since you are rebuilding a rear axle assembly, the attached link may be of help.
Tom Endy
http://www.santaanitaas.org/wp-conte...vised-2014.pdf
Old 08-08-2020, 12:00 PM   #9
Ruth
What is the cutout in the torque tube gasket for? And what position do you put it in, if it matters? I does not match up with anything on the flanges. I notice most of the gaskets from vendors do have the cutout but the one supplied by Mitchell (since you mentioned them) does not have the cutout.
Ruth
Old 08-08-2020, 12:04 PM   #10
redmodelt
redmodelt's Avatar
Good question about the notch. Most all the ones I have seen have them. I have been putting the notch on the bottom thinking it was a lube drain passage.
Old 08-08-2020, 12:27 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
V8 has that ,there is a drilled passage through the banjo on them, perhaps they figured that if v8 has it the a also has it
Old 08-08-2020, 12:55 PM   #12
Ruth
Kurt, I am not familiar with the V8 but the Model A does not have a passage either on the banjo or the torque tube.
Ruth
Old 08-08-2020, 01:52 PM   #13
Conaway2
Conaway2's Avatar
Tom Endy
I’ve been reading this article step by step as I work on the axle. Now, just waiting to get axle housings back form the machine shop with new bearing surfaces installed.
It’s a great, detailed description of the rebuilding process, and I really appreciate all the experience that you;ve documented in it.
Jim
Old 08-08-2020, 01:56 PM   #14
rotorwrench
rotorwrench's Avatar
I've been an aircraft mechanic or too long I guess. I always put a positive safety on bolts with drilled heads. Single wire safeties are OK but I don't align the holes and even if they were, I'd still safety them to apply a righty tighty pull on right hand thread bolts. This will hold a bit of torque on them just in case they work loose for one reason or another.
Old 08-08-2020, 02:05 PM   #15
The Master Cylinder
The Master Cylinder's Avatar
I am not an aircraft mechanic but that is how I was taught and for the same reason.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-08-2020, 04:48 PM   #16
Kevin in NJ
I am pretty sure if the wires are not set up to pull them tight, then they can loosen some.
Pretty sure you dont want them pretty, you want them safety tied.
https://aviation.stackexchange.com/q...g-behind-the-w
Old 08-09-2020, 12:41 PM   #17
ursus
The Model A rear axle design was carried forward to the 1932 Model B, which had a slightly different means of retaining the pinion bearing which allowed for the gasket. The gasket sets are for 28-32 and the gasket is included in the event that the user has a 1932 rear axle.
