Old 08-08-2020, 01:26 AM   #1
Brendan1959
Brendan1959's Avatar
Default Re: Main bearings Babbitt unusual
Originally Posted by Jim Brierley View Post
Looks like that block was set up for full pressure oiling, with a drilled crank for oil to the rods.
The crank is not drilled, I am hopeful this block can be used with these bearings, its a shame the crank has a little rust and some minor pitting, I think this one was stored outside for a while. I have a couple of cranks, perhaps one can be ground to fit. I only have a vernier, so I have ordered a micrometer so I can measure properly. The last picture of the rear-main almost looks like an insert.
The rods have a similar grove, but in the cap and rod.
Its got one x rod as well.
Jim
I have your book and have read it again while in isolation, a good read.
Brendan
Brendan1959 is offline   Reply With Quote
