Old 08-05-2020, 08:20 PM   #1
shew01
shew01's Avatar
Default Tremec T170 Transmission Troubles (this issue may be a puzzle)
Originally Posted by kenparker View Post
Shwe, the "missing teeth in picture five" are NOT missing teeth. That is th way the way they are made. A small "rocker " rocks in that space as you shift between the two gears. Syncros and forks and shifters show some minor wear but not enough to effect anything. Nothing out of the ordinary for a 35 year old trann.
As for the small half circle whatever - got me bumfuzzled.
You’ve worked with these transmissions a lot, if I recall correctly. If it was yours, would you rebuild it? Or, put it together to see if the noise goes away? Or, maybe something else that I’m not thinking of?
