Old 07-11-2020, 10:38 PM   #1
Brendan1959
Brendan1959's Avatar
Default Valve guide tool help needed
Could someone please give the the rough dimensions of a valve guide removal tool like the one below
I cant find mine so i am going to try and spin one up on my lathe.
Thanks
Brendan
Brendan1959 is offline   Reply With Quote
Old 07-12-2020, 08:05 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Valve guide tool help needed
2 13/16" overall length. 1 9/16" narrow shank. 5/8" thick part before taper.
Diameters: 5/8" narrow shank. 3/4" thick shank before taper. 1 3/16" at the top of the flare (bell). The inside of the taper is hollowed out to match the taper of the valve. I'm no machinist, and this is as close as I can measure. After doing the lengths and diameters, you will need to somehow hollow out the middle, so that the tool will wrap around the valve stem for removal of the guides.
Mike Peters is offline   Reply With Quote
Old 07-12-2020, 07:02 PM   #3
Brendan1959
Thanks Mike
Very helpful
Brendan
Old 07-12-2020, 08:18 PM   #4
Brendan1959
Success
Thanks to Mike Peters help
Old 07-12-2020, 11:35 PM   #5
PalAl
PalAl's Avatar
Well I'm impressed with both of you...........
Brendan, nice job cutting that tool, I am so jealous
PalAl is offline   Reply With Quote
Old 07-13-2020, 12:39 PM   #6
Mike Peters
Brendan: Glad I could help. My wife says that this was an international effort. I was wondering how you were going to cut the groove for the valve stem. Milling machine. Very nice.
Old 07-13-2020, 07:22 PM   #7
Brendan1959
Mike
Your wife is right, life as home mechanic was a lot harder before these forums came along.
My milling machine is just a Mill Drill, I have just enough equipment to get by.
Brendan
