Re: 1951 Ford overdrive
I don't know what caused the "gouging" The plate is hardened steel so whatever caused it probably took some time.
As long as I am typing, I have two additional questions. 1. Is the drain plug for the transmission 1" npt? 2. I am also having real difficulty removing the snap ring which holds the speedometer gear in place. I have tried several types of USA made snap ring tools without success. Only one side of the ring moves and not enough to begin to move it up on the output shaft. Any suggestions would be greatly appreciated.
