Old 07-04-2020, 02:24 PM   #4
saxman657
Default Re: Radiator Overheating
Originally Posted by Jim/GA View Post
You started out with water. Did not overheat.
You changed to 50-50 mix water and Prestone. Overheated.
Have you switched back to water and it still overheats?
Or still using 50-50 mix?
I'm back to water and a wetting agent since that seemed to work best. 'm think I may have dislodged some crud into the radiator? Cooling jackets???
saxman657 is offline   Reply With Quote
