Old 06-12-2020, 02:31 PM   #1
Ford coupe
Default Brake fluid gone..
How is the quality of Macs brake cylenders
Ford coupe is offline   Reply With Quote
Old 06-12-2020, 03:46 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Brake fluid gone..
I consider all modern production wheel cylinders suspect, and take apart for inspection of drilled passages, many times the bleeder hole is drilled 1/2 way down causing trapped air, and fluid passages under cup lips
I don't know about macs quality, never bought from them, but every part I was supplied by owners to fix their car didn't work out and was replaced soon after if it worked to begin with, perhaps they have changed after being bought out
Old 06-12-2020, 05:22 PM   #3
Kube
Kube's Avatar
I'd suggest you contact Mike Driskell. I have purchased some cylinders from him and they have been perfect.
Old 06-12-2020, 07:36 PM   #4
JSeery
JSeery's Avatar
My guess would be the same as the other chinese import parts that the cheaper venders sell.
Old 06-12-2020, 07:39 PM   #5
tubman
tubman's Avatar
"Mac's" or Mac Van Pelt?
Old 06-12-2020, 08:20 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
No, no, nO, NO, NO, NO, NO! NO Macs!
See Post #3. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-12-2020, 08:48 PM   #7
Ford coupe
How do i contact??
Old 06-12-2020, 08:58 PM   #8
Zeke3
Zeke3's Avatar
You can send him a private message at 35fordtn.
Zeke3 is offline   Reply With Quote
Old 06-12-2020, 09:01 PM   #9
Branded
Branded's Avatar
How do i contact??
Third Gen Automotive
Phone: 844-327-5988
Url: thirdgenauto.com
2600 Old Nashville Hwy
McMinnville, TN 37110
Here’s his website
https://thirdgenauto.com/about-us/
Branded is offline   Reply With Quote
Old 06-12-2020, 10:00 PM   #10
JSeery
JSeery's Avatar
PM or email most likely won't work, best bet is to call.
