Old 06-05-2020, 05:38 PM   #11
mrlaser
mrlaser's Avatar
Default Re: 1951 Ford overdrive
What I am concerned about whether the balk ring is not in proper position because of the synthetic Gl-4 and as a result, the remediating steps outlined in the BW overdrive manual are unable to move it into proper position due to excessive "slipperiness" (for lack of a more informed term.) The pictures were borrowed from Mac VanPelts excellent article on rebuilding an overdrive transmission. I am a complete novice on this subject and may not have a proper understanding of the function of these parts. It is my suspicion however, that the balk ring is somewhat out of position ( or perhaps incorrectly installed and as a result is preventing the pawl from completely engaging in the slot on the balk gear. As I have previously mentioned, the transmission functions normally with the OD handle pulled completely to the rear and is in freewheeling with the OD handle pushed in. Are there any steps that might clarify the situation that I can take before removing the transmission? Thanks again for any suggestions.Merc-ODtrans-Part10-4.jpg
mrlaser is offline   Reply With Quote
