Zoe,
I'm thinking there's a charging issue / short somewhere in your circuit(s). For a comparative test, I just took out my '36 roadster - 100% STOCK. It is 86° here currently. I ran it to the grocery store, 7.8 miles from here. Parked, bought a few items, got back in, started up immediately and drove home. (hmmm.. no vapor lock, no electric fuel pump and 10% ethanol fuel).I guess I must be doing something wrong... Anyway, drove the 7.8 miles home, parked in the garage, shut it off and carried in the groceries. Went back after about five minutes, allowing the temps to rise after shutting it down. Here's what I got, all in Fahrenheit: Cylinder heads 126° - 137° Intake manifold 134° -136° Starter body 110° -116° Carburetor 109° Fuel pump 106° Water pumps 135° - 141° Generator 105° and lastly: cut out 116° - 117°
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 06-05-2020 at 04:39 PM. Reason: spelling error |
#2 | |
![]() Quote:
Well duh! Maybe you need to question your thinking here. Didn't you know....I was just reading somewhere that you must drive a 6v vehicle for ten miles at highway speed to sufficiently replenish ALL the sparks in your battery that you use-up during each "start". DD |
#3 | |
![]() Quote:
I found it difficult to believe there are some folks that truly think they need to drive their Ford a minimum of ten miles at HIGHWAY speeds to replenish the battery just from the drain of starting. I mean YIKES! Just how long does it take these guys to get their cars to start? Maybe that's the issue? Their cars are not set up properly? Of course there are those that believe nearly everything under the hood is 150°+. Probably the same guys that have to crank their engines over (too) long to get them to start. I say if under the hood is 150°+ all over the place, yeah, they probably have vapor lock. I also say they need to repair their vehicles properly so they start rapidly and run cooler. I suppose these days it's easier to blame ethanol fuels, poorly constructed batteries, etc. rather than actually go to the trouble and expense to fix their vehicles properly. These old Flatheads are not all that difficult to figure out...
