Not all mc have built in residual valves . But i understand your arrangement and the remote fill should work . I would remove the wheel cyl in question and disassemble to inspect the bore , cups and machining .
I just went through a similar, no pedal , on a 30 with juice brakes . All i did was replace some flex lines , bleed and results were a mushy pedal . After much frustration and pulling of my hair . I installed residual valves and problem solved . Mind you this same setup worked for 10-12 yrs until i changed the lines . |
