Old 05-27-2020, 01:28 PM   #1
vista525
Default Source for valve spring shims
Can someone point me to a source for reasonably priced valve spring shims for an 8BA. Red’s has them in three sizes for a great price but the shipping is a killer ($22 bucks on an $18 order). I suppose $21 of that cost is California taxes so I can’t hold it against them. Speedway only carries them in one size and apparently they must be gold plated and hand forged by hot rod monks on a mountain top in the Himalayas. As proof that I’m not a cheapskate I’d like to submit that my 49 F1 does not have a small block Chevy. Any chance there’s a NAPA part number(s) I’m missing? Thanks
vista525 is offline   Reply With Quote
Old 05-27-2020, 01:40 PM   #2
40cpe
40cpe's Avatar
Default Re: Source for valve spring shims
GOSFAST here on the 'Barn handles a lot of flathead valve related parts. you might try to PM him.
Old 05-27-2020, 01:55 PM   #3
G.M.
Valve springs need to be measured with a special valve spring measuring
machine. A load is put on the spring and it should be a specific length at
a measured amount of pressure. G.M.
www.fordcollector.com
Old 05-27-2020, 02:09 PM   #4
Mart
Mart's Avatar
Yeah, it's called bathroom scales on a drill press.
Old 05-27-2020, 02:19 PM   #5
vista525
Yep got a spring scale.
Old 05-27-2020, 02:32 PM   #6
G.M.
Very precise. G.M.
Old 05-27-2020, 02:46 PM   #7
vista525
Thanks.
Old 05-27-2020, 03:43 PM   #8
flatheadmurre
flatheadmurre's Avatar
Go to your local machineshop and ask for A-101 B-101 or C-101 valvespring shims...not sure i ever used a .015 balancing shim on a flathead though.
They cost $20 for a box of 100 so even if they double their money it cant be to bad...lol
Old 05-27-2020, 04:25 PM   #9
KiWinUS
KiWinUS's Avatar
Murre nailed it , or go direct to Goodson , shims cheap S&H will hurt though.
Old 05-27-2020, 08:11 PM   #10
vista525
Great idea. Thanks for the part numbers!
Old 05-27-2020, 09:28 PM   #11
eicke
Yep....more accurate that the tool designed for the purpose!
Mart,
You need to do a video on this...…..
-Ron
eicke is offline   Reply With Quote
Old 05-28-2020, 07:43 AM   #12
richard crow
what do you need them fore the higher the spring pressure the more load on the camshaft & lifters let us know how maney times you put your eng over 4,000
richard crow is offline   Reply With Quote
Old 05-28-2020, 08:38 AM   #13
Kube
Kube's Avatar
A properly done valve job always includes measuring the spring load at a very specific compressed height. To simply take a spring out of the box and install it is less than professional. Especially these days when quality of parts is too often questionable.
Old 05-28-2020, 08:42 AM   #14
KiWinUS
KiWinUS's Avatar
Amen
Old 05-28-2020, 08:53 AM   #15
flatheadmurre
Measuring to verify is good...then comes the question of how good between springs is enough...i have never ever installed a balancing shim on a flathead at this low springpressures it´s not a hair between make it and break it...
Old 05-28-2020, 09:04 AM   #16
GOSFAST
GOSFAST's Avatar
If you end up ordering the spring shims don't waste your money ordering the "C" series (.015") you won't have much use for them!
Thanks, Gary in N.Y.
P.S. A single "C" shim (.015") will change the pressure by about 1 pound, we gave up stocking them a few years ago! We only keep the "A's" (.060") and the "B's" (.030"). The "B's" will change it by less than 5# and the "A's" less the 10#.
GOSFAST is offline   Reply With Quote
Old 05-28-2020, 10:48 AM   #17
barnfind
If you have NAPA in your area check with them.
barnfind is offline   Reply With Quote
Old 05-28-2020, 11:46 AM   #18
Ronnie
Ronnie's Avatar
Check with your local machine shop they may have them but can order them for you.
R
Ronnie is offline   Reply With Quote
Old 05-28-2020, 06:40 PM   #19
vista525
I’m not building a racing engine but I have to agree with Kube on this one. If I’m going to assemble the engine I’m going to do it to the highest possible standard I can. If nothing else it will make me feel better.
Old 05-28-2020, 06:44 PM   #20
vista525
Awesome post script! Glad you shared this info. The #change for each shim will definitely be helpful for anyone who stumbles on this thread.
