Old 05-26-2020, 03:10 PM   #1
Vern A
Default New Clutch Slipping
I just replaced the clutch disc, pressure plate and throw out bearing on my 1932 Ford pick up and it still slips at higher speeds when accelerating. I'm running a stock 1940 Flathead and a Borg Warner T5 five speed. The adapter came from Speedway Motors. I've tried adjusting the clutch but it doesn't help. Everything is dry. I've worked on and built a lot of cars over the years but this kind of has me stumped. If anyone has any ideas I'd really appreciate it.
Vern A is offline   Reply With Quote
Old 05-26-2020, 05:05 PM   #2
JSeery
JSeery's Avatar
Default Re: New Clutch Slipping
I would assume that if it is slipping at higher rpms that the pressure plate is not clamping the disk with enough pressure for it to hold. If so you would need to figure out why, clutch disk thickness? Pressure plate springs? Etc.
Old 05-26-2020, 05:14 PM   #3
tubman
tubman's Avatar
Is it a 9" clutch? How big?
Old 05-26-2020, 07:27 PM   #4
cas3
i think 40 would still be a 9" with the blob
Old 05-26-2020, 07:44 PM   #5
tubman
tubman's Avatar
You're probably right, but with a '40 engine in a '32 pickup using a T5, it's probably not a good idea to assume anything.
Old 05-26-2020, 07:46 PM   #6
cas3
very true
Old 05-26-2020, 08:03 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
How thick is the disc that was used
What flywheel was used-- the 32 flywheel uses about the same clutch as model A
Old 05-26-2020, 08:31 PM   #8
Vern A
It's a 9" clutch pressure plate for a '40 Ford and a pressure plate with the T5 splines. The disc seems to be the same thickness as the original one that came with the T5 adaptor kit from Speedway. The engine has never been rebuilt so its original 85hp which is somewhat less now days, isn't overpowering anything I shouldn't think. All the parts are new.
Thanks guys.
Old 05-26-2020, 08:32 PM   #9
Vern A
The flywheel is '40 Ford
Old 05-26-2020, 08:41 PM   #10
petehoovie
petehoovie's Avatar
Did you have the flywheel refaced or did you rough it up with sandpaper?
Old 05-26-2020, 09:18 PM   #11
Vern A
Did the sandpaper thing
Old 05-27-2020, 03:30 AM   #12
Ray Balukas
Ray Balukas's Avatar
Im not familiar with t5 set-up,but I run a 9" in my 37 panel . Stock 8BA 3 speed Trans. Walt Dupon
t suggested running the 9" with heavy duty springs. I've had it in for 3 years with no slipping problem. Call Ft Wayne Clutch. Talk to Kerry he is familiar with this setup. I forgot to add the first 9" stock clutch did start slipping, when I ordered it I forgot to mention beefing up the springs. The truck had an 11" set-up. "Walt's words were get rid of the 11", its added weight. " It's all about horsepower" Good Luck
Ray Balukas is offline   Reply With Quote
Old 05-27-2020, 07:39 AM   #13
1931 flamingo
1931 flamingo's Avatar
How much free play?? Were all 3 fingers at the same height??
Paul in CT
Old 05-27-2020, 08:03 AM   #14
AnthonyG
AnthonyG's Avatar
If it’s still assembled make sure linkage is clean @ pivot points & check ur linkage for any slight bends that might bind. Small bit of grease on pivot points. When I assemble my ‘35 I had similar issue & turned out a bent part of linkage binding. Straitened, cleaned, & lubed resolved. Worth a check before disassembly for other issues.
Nomad
AnthonyG is offline   Reply With Quote
Old 05-27-2020, 08:30 AM   #15
deuce_roadster
deuce_roadster's Avatar
Not sure if this could cause your issue but a friend of mine (who owns a machine shop) bought a Speedway adapter for a GM 4 speed and because he is a machinist, he checks everything and the machining on the opening for the transmission was off by quite a bit and he had to adjust it. If you take it apart I would check all important measurements and angles, maybe the mounting surface isn't exactly 90 degrees to the CL of the trans.
However I would measure your disk thickness with a micrometer and compare it to a stock Ford disk. I believe the difference between engaged and disengaged is only something like .050 movement on the pressure plate and if the non Ford disk is just a few thousands thinner it could be the problem too. Good luck.
Old 05-27-2020, 09:11 AM   #16
Automotive Stud
Automotive Stud's Avatar
Hydraulic clutch?
Automotive Stud is offline   Reply With Quote
Old 05-28-2020, 06:59 AM   #17
Frank Miller
Frank Miller's Avatar
Is it slipping in all gears or just 5th. Maybe a borderline pressure plate that is not doing well with the extra load. You did properly tighten the pressure plate bolts, right? If you take it apart I would start with snugging up the pressure plate until it just holds the pressur plate and then measure distance from the plate to flywheel to get an idea how much it is compressing. If you have an extra clutch and flywheel maybe you can measure the torque required to tighten the pressure plate to compare spring tension. If there is a truck clutch and brake place near you maybe they can help you determine spring pressure.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-28-2020, 07:34 AM   #18
richard crow
what is your rear end gearing if it,s high when your in fith it,s even higher.if all clerance checks out send pressure plate to fort wayne clutch have them increase spring pressure
richard crow is offline   Reply With Quote
Old 05-28-2020, 08:01 AM   #19
deuce_roadster
Good question from Richard crow. A 9" clutch with an overdrive trans with tall gears would be pretty much guaranteed to slip a 9" clutch in high gear. Besides the rear end ratio, how tall are your rear tires?
Old 05-28-2020, 08:08 AM   #20
Vern A
Thanks guys this gives me a few things to check out for sure. The rear end is out of a '40 Ford and has 4.?:1 gears in it. I bought it that way and never had it opened up to check exact ratio. The trans has 28% overdrive. I'll check the concentricty of the adaptor to the crankshaft pilot bushing. I'll recheck my mechanical clutch linkage as well. The free play on the pedal is good.
Vern.
