Old 05-23-2020, 07:30 AM   #1
Dean Lemoine
Dean Lemoine's Avatar
Default Modern distributor cap
Is there a difference in performance of the modern style distributor cap and wires versus the original cap and bronze spark plug connectors?
Dean Lemoine is offline   Reply With Quote
Old 05-23-2020, 07:41 AM   #2
emf
emf's Avatar
Default Re: Modern distributor cap
Quite a bit of difference. With the modern cap the engine won't misfire when it gets wet, modern wires won't emit huge amounts of RFI when the car is running.
Frank
emf is offline   Reply With Quote
Old 05-23-2020, 09:27 AM   #3
old31
But the modern caps just dont look right to me.
old31 is offline   Reply With Quote
Old 05-23-2020, 09:42 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I prefer the original distributor cap , first for the original look . The gaps can be measured between the rotor tip and the 4 contacts in the distributor cap . The 4 contacts can be filed for equal gaps at all four contacts in the original cap . I consider equal gaps as part of a tune up . I prefer a gap of .035 between the rotor tip and the contacts in the cap for equal and hotter spark at all cylinders . Measuring gaps at the rotor tip isn't possible with the modern style distributor cap .
Old 05-23-2020, 11:19 AM   #5
Dean Lemoine
Thanks guys. I agree with the original look and honestly I hadn’t thought about the ability to check and adjust the gaps. If there is/was a significant performance increase, I was thinking about going with the modern cap and wires. Stay safe.
Old 05-23-2020, 12:06 PM   #6
redmodelt
redmodelt's Avatar
Maybe the worry about setting air gaps is not as important with modern caps? How often to you see info about people setting air gaps on later V8 or any car up to electronic ignition?
Old 05-23-2020, 12:12 PM   #7
MAG
MAG's Avatar
Just thinking,,, if electricity travels at roughly 11, 628 inches per second how long does it take for the spark to jump .025 or .035?
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 05-23-2020, 01:38 PM   #8
Purdy Swoft
While it is possible to measure and adjust air gaps with the original model A or B distributor caps, I don't see how measuring air gaps would be possible with a modern style distributor cap .
Air gap distance won't make a day and night difference in performance but there does need to be air gaps for the spark to jump . Ford recommended gaps of twenty five thousands at the rotor tip . More gap to a certain point will increase spark intensity . I set mine at thirty five thousands . I believe that equal size air gaps at the rotor tip will send equal spark to each cylinder for better performance .
Old 05-23-2020, 02:09 PM   #9
Ruth
I like putting a clear distributor cap on the distributor body. At night the little ones like to see the "sparklers". You can't do that with a modern distributor cap.
Ruth
Old 05-23-2020, 04:58 PM   #10
Joe K
Joe K's Avatar
Someone made up a Model A distributor body (the bakelite part) entire. A one-off I think. I'd like one of those.
Sort of like painting the engine red - proven to make the car go faster.
Joe K
Shudda kept the horse.
Old 05-23-2020, 05:00 PM   #11
keyswitch1
Who sells the modern style distributor cap and wires ?? Thank you !
keyswitch1 is offline   Reply With Quote
Old 05-23-2020, 06:23 PM   #12
Bob C
Snyder's has them. https://www.snydersantiqueauto.com/P...-a/distributor
Old 05-24-2020, 09:50 AM   #13
Purdy Swoft
If the original style distributor cap body and cap was made as one part , you would lose the ability to measure and adjust the air gaps . I've used and found NO advantage to a modern style distributor cap when used with the original model A distributor .
Old 05-24-2020, 10:14 AM   #14
katy
katy's Avatar
No difference in performance.
katy is online now   Reply With Quote
Old 05-24-2020, 10:37 AM   #15
DBSHELTON
Maybe no better but to use some heads like my Lion Speed, you have to go with the modern style cap and wires
DBSHELTON is offline   Reply With Quote
Old 05-24-2020, 02:45 PM   #16
divcoone
divcoone's Avatar
Mikes was selling the “A” style cap that could be used with modern cables.
divcoone is offline   Reply With Quote
Old 05-24-2020, 04:34 PM   #17
john in illinois
john in illinois's Avatar
I have an original style cap and have driven long miles in the rain and never had an engine miss from the bronze spark plug connectors.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 05-24-2020, 08:36 PM   #18
CarlG
CarlG's Avatar
I have one of those on my engine. They are made by Renner’s Corner which is where I bought mine. Works / looks great. Best of both worlds??
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-24-2020, 09:09 PM   #19
Chris Haynes
Chris Haynes's Avatar
Back in the '60's I had a clear modern cap. You could watch the rotor spin and points break.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-25-2020, 02:31 AM   #20
dumb person
dumb person's Avatar
They just don't look the same.....
That's the thing, The time for the coil to build up enough juice to jump the gap is measurable. I've never measured it myself, but when i was making electronic ignition, if the gap was too wide i needed 12ms of coil activation time versus 2ms for normal plugs.
And all the clear cap comments make me wonder how hard it'd be to make a mould and cast one in resin.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
