Old 04-07-2011, 01:17 PM   #5
31Tudor
31Tudor's Avatar
Default Re: 29 Closed Cab Pickup Rear Window
Ok, I have a 28 Pickup and I was sitting at work trying to visualize the back window. I was thinking there was a frame look on the outside of the cab box but I guess it is the stamping and then the nuts and bolts going through it, so you and Dudley are correct there is not a molding outside, sorry bout that. I am thinking that I still would definately install the inside molding, that really does hold it all together. Maybe you can have a glass shop either shave the glass down or cut a new one to fit in the back panel with the rubber around the window and the molding installed.
31Tudor is offline   Reply With Quote
