Old 04-26-2020, 05:31 PM   #21
burner31
burner31's Avatar
Default Re: What do you carry with you?
Because I read the news, along with some basic tools and some extra parts.
Don't leave home without it.........
Keith
Shawnee OK
'31 SW 160-B
Old 04-26-2020, 05:37 PM   #22
Jacksonlll
Jacksonlll's Avatar
I really think the canvas tool roll is the berries. Bucket boss has the expensive ones, but there are good ones for less than $10. Unroll it and you have all your tools.
Old 04-26-2020, 06:06 PM   #23
Synchro909
Synchro909's Avatar
When we are on a long trip, we are usually outside phone range so I have to expect that if the car stops, I am the one who will have to get it going. I carry a set of tools (spanners, screw drivers, pliers etc,, jack and handle. There is a distributor and carburettor (never have needed either), some electrical wire, fan belt and test light. A spare tube (from when we couldn't get a decent one) is always there and a stick of Kneedit (an epoxy putty).
Because a repair might take a while, we have a toilet roll, food and water. We have had to make some what I think are clever improvisations but we've always gotten home. IMO, the best thing to take is the gap between your ears filled with knowledge about your car.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 04-26-2020, 06:07 PM   #24
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by McMimmcs View Post
Why not just a AAA card and a cell phone. It must be terrible contemplating a breakdown every time you start the A. Can’t imagine your trips are much fun ! O
IMO, there is no reason to have to "contemplate a breakdown every time you start" a well maintained Model A. I go over my model A after a outing and check it again before the next.
Yes things can happen, but they can happen on a modern also. I'm certainly not going to let it spoil my fun.
That said, I do carry a small tool box, Halotron fire extinguisher and a first aid kit 'just in case'.
Old 04-26-2020, 06:14 PM   #25
daren007
Fan belt? Carburetor? Ok now how many of you have ever needed either one. I carry a screwdriver.
daren007 is offline   Reply With Quote
Old 04-26-2020, 06:48 PM   #26
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Yes. Not a complete carb but parts of the kit. After apparently getting bad gas, and having the carb apart 3 times coming home.
The belt, was after replacing the fan belt as part of "good maintenance". Did it while I had the radiator off, why not, I was there. Threw the take off under the seat. The new one separated about 30 miles from home, ( about a month old, maybe a hundred miles on it.) Put the take off back on and drove home.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 04-27-2020, 07:57 AM   #27
Bob Bidonde
Bob Bidonde's Avatar
I run my 190A out of state to New England Meets, and here is what I carry onboard. 99% of this stuff fits in the front tool box shown in the photo:
Abrasive Paper
Axle Hub Gasket (2)
Axle Keys (2)
Blanket
Cable Ties
Clamp (2)
Coil 12V, Internal Resistor
Coil Hi-V Wire
Condenser OEM
Condenser, Modern
Cotter Pin Pick
Crank & Lug Nut Wrench
Crimper, Wire Terminal
Cylinder Head Eye Bolts (2)
Distributor, Rebuilt
Drum Puller
Extension 3/8 x 3”
Extension 3/8 x 6”
Feeler Gage
File Rat Tail
Flashlight, LED
Float Valve Shim Set
Garmin GPS
Gasket Paper
Gasket Scraper
Gasket “A” Water Pump
Gasket “B” Water Pump
Gasket, Cylinder Head
Gloves
Grease
Grease, Dielectric
Hammer, Ball Peen
Hardware Assortment
Ignition Point Posts (2)
Ignition Point Set, OEM
Ignition Point Set, Modern
Insurance Policy
Jack & Handle
Knife, Utility
Magnet, Telescoping
Marker, Black Sharpie
Mirror
Motor Oil 10W30, Quart
Multimeter
Nut Drivers 3/16, 1/4, 5/16
Nut Drivers 11/32, 3/8
Nut Drivers 7/16, ½
Paint Brush 2”
Pin, Valve Stem
Pliers, Slip Joint
Pliers, Diagonal
Pliers Visegrip 7”
Pliers, Water Pump
Putty Knife
Rags, Several
Ratchet 3/8 Drive x 6”
Ratchet, Swivel Head
Registration & Insurance
Rod, Plastic
Rope, 32”
RTV Silicone, Tube
Seal, Rear Wheel Bearing
Scissors
Scotchbrite Cloth
Screw Driver, Offset
Screw Driver, Phillips
Screw Driver w Holder 1/8
Screw Driver 1/4
Screw Driver 1/4, Short
Screw Driver 5/16
Screw Driver, Large
Shims, Rear Axle (2)
Socket Adapter 1/4 - 3/8
Socket Adapter 3/8 – 1/2
Socket Adapter 1/2 - 3/8
Socket 3/8 Dr x 1/2
Socket 3/8 Dr x 7/16
Socket 3/8 Dr x 1/2
Socket 3/8 Dr x 9/16
Socket 3/8 Dr x 5/8
Socket 3/8 Dr x 11/16
Socket 3/8 Dr x 3/4
Socket, Timing Gear Nut
Spark Plug TT10
Spark Plug Gap Tool
Stop Leak, Barr’s
Tape, Electrical
Tape, Duct
Test Light, Coil
Test Light, Hi-Voltage
Rain-X
Rotor
Timing Gear
Timing Pin w Key Ring
Tire Irons (3)
Tire Pressure Gage
Tube Patch Kit
Tube Valve Service Tool
Tube Valve Puller
Tooth Brush
Towels, Microfiber (3)
Towel, Terrycloth
Valve Guide Driver
Water, 1 Gallon
Water Pump, “A”
Wheel Bearing Set, Front
Wheel Bearing, Rear
Wire AWG 16 x 24”
Wire Brush
Wire Hangar
Wire Strippers
Wrench, Adjustable 4”
Wrench, adjustable 10”
Wrench 1/4
Wrench 3/8
Wrench 7/16
Wrench 1/2
Wrench 9/16
Wrench 5/8
Wrench 11/16
Wrench 3/4
Wrench, Carburetor Jets
Wrench Set, Allen
Wrench, Nu Rex Timing
Bob Bidonde
Old 04-27-2020, 11:13 AM   #28
daren007
Are you serious?
Old 04-27-2020, 11:14 AM   #29
katy
katy's Avatar
Originally Posted by history View Post
definitely a sig p365, am curious also on what other than the sig is a necessity.
ammo
Old 04-27-2020, 11:27 AM   #30
Ruth
Are you serious?
I think Bob is being facetious. Looking at his list, several of his items are duplicates or combined with another item.
Ruth
Old 04-27-2020, 12:10 PM   #31
McMimmcs
McMimmcs's Avatar
B]That is the funniest, most outrageous post I have ever seen! Hopefully after he gets his laughs he will send us his real list! Hahaha[/B]
Old 04-27-2020, 12:18 PM   #32
daren007
I did notice all that and no fan belt.
Old 04-27-2020, 01:27 PM   #33
The Master Cylinder
The Master Cylinder's Avatar
Bob needs to add a couple of fuses and or circuit breakers, fire extinguisher, first aide kit and a fan belt. Maybe a trailer hitch and trailer... to tow the spare Model A.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 04-27-2020, 07:48 PM   #34
30 Closed Cab PU
When on a trip with other As, sure would be happy if I broke down and someone like Bob was with. More fun to quick fix and be on my way instead of ending my day waiting for a tow truck.
Old 04-27-2020, 07:58 PM   #35
History
History's Avatar
Bob is definitely the guy we all want to be cruising with us. He should eat free at all the stops.
History is offline   Reply With Quote
Old 04-27-2020, 10:17 PM   #36
McMimmcs
McMimmcs's Avatar
Yes unless you needed something simple like a fan belt haha !
Old 04-27-2020, 11:26 PM   #37
Aarongriffey
The usual plus a bottle of aspirins, a few nitro tablets and a wire cutters.
The jack, spare tire, tool bag should go without mention.
A roll of paper towels can be handy too.
Aarongriffey is offline   Reply With Quote
Old 04-27-2020, 11:33 PM   #38
Aarongriffey
A roll of paper towels, as already suggested, can de handy.
Did anybody mention dry hand cleaner?
Old 04-28-2020, 02:17 AM   #39
dumb person
dumb person's Avatar
I should have a tire pump and fan belt, but i can't find a tire pump anywhere. And anyone under 50 seems to be "What's a V belt?".
I do tend to carry a tiny bottle of oil. Swiss army knife, screwdriver or 2. adjustable spanner. And lately i've been reminded of the value of a packet of chewing gum. Can patch all sorts of leaks with that.
Also, a candle and piece of soap. Amazing what you can lube or patch with those. A stick that you can carve threads into with a pocket knife is handy if you lose a sump plug too.
Definitely a sig p365, am curious also on what other than the sig is a necessity.
I'm really curious how bad things are that you need that. A 410 make sense for rabid raccoons but wtf?
This is not to be underestimated. If more people did this (regardless of what brand car they drive), there'd be a lot less break downs in the first place.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 04-28-2020, 03:51 AM   #40
Blue-Truck-Nut
Bob made a nice post, but I'm curious, I see masking tape in the bag but not on the list? Also, where's the head gasket? I didn't see it on the list or in the picture?
Something I try to do, is carry proven ignition parts. As in not buying new ones for the road kit. I'll do a tune up when the car is running fine, polish the points, and carry those. Nothing more aggravating than defective new parts. Except digging through all the junk I carry trying to find said parts.
Anybody carry road flares? Or reflectors?
