I have recently installed new motor mounts when I replaced water pumps. Also have a new rear trans mount, planning to install.
Just out of curiosity, what are the symptoms that you are changing out the clutch? Just changed my '40 clutch which was very smooth operating, no chatter and the flywheel was fine. Pulled the rear end back to access.
I can't adjust it any further to make it release. The PO added length to the adjustment and now there is no more. Also won't go into gear without grinding. It always has had some chatter but if you released the clutch fully before giving it any gas it was pretty smooth.
Hey Darrell,
I'm going to send you PM, as I can not see PP pic (inside) clearly. As for the disc. This disc does not have the small 'ears' the capture the springs. In this case, these springs CAN wear , become loose (make rattling noise) and even leave their assigned areas...all not good. Lots of work to remedy these if / when any of this happens. Would a guy take a chance of any of this happening, if a better disc is available to use to prevent...your choice. |
#5 | |
![]() Quote:
#6 | |
I'd be surprised if Fort Wayne wouldn't have them also. Worth a call. Last edited by hardtimes; 03-09-2020 at 03:25 PM. Reason: ....... |
