Old 03-07-2020, 10:56 AM   #1
1stford
1stford's Avatar
Default Throw out bearing
Is there an “easy way” or trick to replacing a throw out bearing on a 36 truck without having to remove everything?
What’s the best process for this?
1stford is offline   Reply With Quote
Old 03-07-2020, 11:21 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Throw out bearing
No easy way.You have to pull the trans.2 ways to do it.Pull the engine or drop the rear end and pull it back. Pulling the rear is the least PITA,IMO.Either way its a PITA.Make sure the clutch and PP is good before reassembly.
Old 03-07-2020, 11:29 AM   #3
1stford
1stford's Avatar
What is the “PP?”
Old 03-07-2020, 11:30 AM   #4
1stford
1stford's Avatar
I almost think it’s worth just having a very loud racket on tbt throw out bearing no more then it’s getting driven VS taking it apart.
Old 03-07-2020, 11:35 AM   #5
deuce lover
Pressure Plate.Also replace the hub return spring if you do the job.
Old 03-07-2020, 11:41 AM   #6
1stford
1stford's Avatar
All of these parts are new, the truck has about 100 miles on it. I’m thinking (hoping) its the throwout bearing that maybe I had it adjust wrong.
Old 03-07-2020, 11:47 AM   #7
deuce lover
The only adjustment for the throw out bearing is the linkage from the clutch pedal to the arm on the trans.There should be maybe 1/2-3/4" play on the pedal before it engages the TOB. .You might have it to tight.Do you have a USA bearing or offshore?
Old 03-07-2020, 11:49 AM   #8
1stford
1stford's Avatar
I’m going to take the floor out and check it. The bearing is what Mac Vanbelt sent when he rebuilt the tranny.
Old 03-07-2020, 11:52 AM   #9
1stford
1stford's Avatar
Would a bad TOB make a terribly awful sound of metal grinding? It’s intermittent so I’m a 10 minute drive I might here it a couple times? It happens with clutch in.
Old 03-07-2020, 11:52 AM   #10
deuce lover
Then the bearing should be good.Is that little return spring connected? You can see that when you remove the insp cover.Metal grinding sound - not good.
When I first got my '33 together and running I had a similar sound ,I had no play in the pedal.It was to tight-in other words the bearing was constantly riding on the clutch fingers.I backed off on the adjustment and it cleared up.
Old 03-07-2020, 12:00 PM   #11
1stford
1stford's Avatar
Would that be a Stroke of good luck for me! Unfortunately I don’t usually have that kind of luck!!
Old 03-07-2020, 12:01 PM   #12
1stford
1stford's Avatar
When I have pull that off should I re grease the TOB?
Old 03-07-2020, 12:14 PM   #13
deuce lover
Try messing with the adjustment if there is no play.If to far off you won't be able to get it in gear while running.I think the bearing is sealed.
Old 03-07-2020, 12:26 PM   #14
tubman
tubman's Avatar
I wouldn't do anything too extreme until I talked to van Pelt.
Old 03-07-2020, 12:34 PM   #15
JSeery
JSeery's Avatar
There really isn't anyway to grease a throwout bearing. When is it making a noise, clutch pedal in, out, changing gears, just driving along?
Ok. Just notices you had posted clutch in.
Old 03-08-2020, 06:41 PM   #16
hardtimes
hardtimes's Avatar
If Mac sold you the TOB, then you got American made best !
100 mi use may not seem like much, but if that bearing has been too tight all that time....well, they are not bullet proof from abuse.
Question: how long did you run it , during the 100 mi, till you started hearing the 'squeal' ? Once they make that type noise....I'd replace it, as it will only get worse with time. However, proper adjustment may give more time/service until ?
There is a way to grease, but the average guy is not going to do that. And that would be best done on the bench.... while it feels/looks usable yet.
Old 03-08-2020, 11:26 PM   #17
Talkwrench
Talkwrench's Avatar
I just did all that with mine. It was a Atena brand [American?] It spun far too easy for a throw out bearing. I returned it and got a National one.. You really shouldn't be able to spin them as they are packed with grease. Maybe thats your problem..?
https://www.youtube.com/watch?v=ShFS...ature=youtu.be
Old 03-08-2020, 11:48 PM   #18
redmodelt
redmodelt's Avatar
Could have been installed the wrong way and fingers are rubbing on non turning back side of bearing. Would not be a first.
Old 03-09-2020, 05:39 AM   #19
48-710
Redmodelt x 2
48-710 is offline   Reply With Quote
Old 03-09-2020, 08:12 AM   #20
swanwaco32
I found out that you do not use on that comes in an unmarked white box..!!
swanwaco32 is offline   Reply With Quote
