01-08-2019, 01:00 AM | #41 |
Re: Water Temperature Gauge
I bought mine a little over a year ago and it works fine.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-08-2019, 01:20 AM | #42 |
I bought an Apco and used a new outlet with the hole in the side for the probe. It works great, BUT, the under the speedo bracket really sucks. Really hard to deal with the e-brake lever. Not only that, but the #**&!# repro chrome bezel that doesn't fit all that great to begin with is nearly impossible to get the gauge bracket screwed on. Grrr.
Anyone know of a reasonably inexpensive single gauge steering column mount? Mine is a '29. |
01-08-2019, 05:04 AM | #43 | |
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 01-08-2019 at 11:18 PM. |
02-23-2020, 04:06 PM | #44 | |
02-23-2020, 06:51 PM | #45 |
I believe Mark Maron recommends the Vintage Precision tstat and temp gauge. It's a little pricey and I have not decided yet. Not real excited about the temp gauge in the rad hose.
http://www.vintageprecision.com/products/thermostat |
02-23-2020, 07:07 PM | #46 |
02-23-2020, 08:21 PM | #47 |
just finished installing a temp gauge yesterday, but before I hooked it up I tested it in a pot on the stove and it worked just fine. it is an APCO gauge.
02-23-2020, 08:43 PM | #48 |
James A... One more option that's out there
05-17-2020, 07:26 PM | #49 |
That is great how the sensor goes up under the hood and must be almost unnoticeable. I'm going to put in one that mounts on the goose neck and the sensor line is visible along the side of the head which will not look so "hot" (ouch, how corny).
